Legally, you don't. Routers have a password reset method to log into them, then you can check out / change the password for the network.
Assuming you're talking about a wireless network, it depends on the encryption. WEP encryptions can be cracked with injection soft/hardware... I know there are a couple of apps that do that in linux. For WAP encryption, good luck. :)
when i go on to the website recomended (http://192.168.1.1) it tells me under the WLAN section...
(More)
when i go on to the website recomended (http://192.168.1.1) it tells me under the WLAN section everything except the WEP key and in the place where the WEP key should be it just says 64bit wep and i have tried so manny things and it just isnt working HELP!!!!!! thanks
i've been using this belkin router for 6 months on my XP pcs. now, i lose my internet connection as...
(More)
i've been using this belkin router for 6 months on my XP pcs. now, i lose my internet connection as soon as i plug in the cable between router and modem. as soon as i unplug the wired cable between router and modem, the connection is just fine. if the router is not plugged into the modem, all lights are on the modem. when the router is plugged in, all lights are on except internet on the router. so far i have: -checked the cables, all fine -checked the router on another computer, works fine -reset factory settings and reinstalled ware -power cycled about 1000 times -gone to the 192.168 page and tried to check settings, all seem OK but still get "no internet" status -called my ISP. Their response was "don't use the wireless router, since it affects your service." i am not sure where to go from here. if you have any suggestions I'd love to hear. thank you
my psp wont connet to the internet i had the MAC adress of the PSP added to exceptions list on my...
(More)
my psp wont connet to the internet i had the MAC adress of the PSP added to exceptions list on my motorola SBG900 modem page (192.168.0.1), as well as adding it thru the NEW NAT PASSTHROUGH section (bypass firewall on), and i wen to PSP, flick on WLAN switch, went to network settings/infrastructure mode, scanned for network, my modem appears to be there with 100% signal frequency. and then i entered everything correctly, but when i test i get a message saying: "connection to the access point cannot be established" by the way my psp is a PSP-2002 model on version 5.51 and i also have McAfee installed on my computer. do i have to add the device to mcafee or somthing else? seriously this is getting kind of annoying :(
It is netcom NP740n and not NB5PLUS4W Hi everyone my name is Eli from Sydney I have new Netcom...
(More)
It is netcom NP740n and not NB5PLUS4W Hi everyone my name is Eli from Sydney I have new Netcom wireless router NP740n I cant set up, the instruction says to make it bridge then go to 192.168.1.1 but it is not going anywhere, I have set it before but i haad problem of connection and disconnection for no reason every minute and when i tried to set it again it is going no where
Dell TrueMobile 2300 Router My cable modem works fine when connected to my computer. When I try to...
(More)
Dell TrueMobile 2300 Router My cable modem works fine when connected to my computer. When I try to connect to my router...there is no connection. I connected Ethernet cable from Modem to Router Then connected Ethernet cable from Lan 1 to Computer... The internet connections works just fine until I try to use it with the router. I have cable internet through Charter Communications What am I doing wrong??
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
