Question about Canon Pixma iP6600D InkJet Photo Printer
Paper jam when paper cross-loaded, removed paper. Now error code 5100
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The error 5100 means it is a Carriage Position Error. The plastic strip that runs the carriage might get some particles of paper or rust and required to be cleaned with some alcohol and swab. If still the problem persists, then it may be due to some obstruction in the print path or gears or some ink on the clear plastic encoder strip. Lubricate the sliders with some white grease, including the purge cap, which is the white sliding mechanism that the print head parks on when it's not in use. Please make sure that it is not split on the small wipers or the black caps. The mechanism can now slide more freely. To access the purge mechanism you need to remove the right panel off of the printer. There are two screws on the behind of the printer and two in front for each side panel. You can locate the front screws behind the grey front panel of the printer. Now open the top cover to see the clips which hold the front cover on.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 29, 2009
How do I clear a 5100 error code? The part of the printer with the ink cartridges is lodged way back in the machine. There is no paper jammed in it
You do not say which model printer you have.
However error code 5100 usually comes up after paper jam.
The error indicates 2 possibilities, either their is something stuck or a sensor detecting the paper jam issues is faulty.
1. turn off the unit....unplug the power cable
2. Remove the cartridge...manually slide the carriage assembly\ printhead back and forth.
3. Clean the rail against which the assembly slides with a tissue ensuring that there is no ink residue on it.
4. Clean the gold contacts of the cartridges and the printhead with a cotton swab dipped in little alcohol.
5. Check the paper feed tray, roller assembly area and the area where the carriage moved for any stuck obstruction like paper, paper clips, pins etc and if found remove it.
6. Turn the unit back on and check
7. If error 5100 continues, then an electric sensor that detects paper jams is faulty.
Sensors can be costly to repair/replace and it is often more cost effective to opt in for a new unit.
Feb 25, 2018 | The Office Equipment & Supplies
I tried to print something and the paper got jammed and now I have an error code 5100. What does this mean and how can I clear it? I have removed the jammed paper. please help me
the solution is to clean the strip film,look for the paper sensor is not broken or blocked
5100 means
- Carriage unit
- Timing **** film
- Logic board
- Carriage motor all this
Feb 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have an error code 5100. It started grabbing the paper wrong and a piece got jammed. I removed it and then it says error 5100. I have turned it off and on a few times and it is still there.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 04, 2010 | Canon PIXMA MP470 All-in-One Printer
What does error code 5100
For error 5100 try the following, I know it works on some Canon printers:
Unplug printer, press and hold "resume" button, press "power" button and hold down, release "resume", press "resume", release and press again. Release both buttons and now press "resume" 4 times. Power off. Re-start.
Hope this helps
Aug 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Paper jam on canon pixma mp600
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Jun 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a Canon MX700 printer. I had a "business card paper" jam. Since the paper is perforated for business cards, it wasn't fun removing all the pieces. I finally removed the back panel & was able to...
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Feb 18, 2009 | Canon MX700 Office All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
55 people viewed this question
old marine
old marine
