Question about Mitsubishi WS-55809 55" Rear Projection Television
Same mitubishi, identical problem
I went to the website selling the parts and they only list a convergence fix kit, not the fluid replacement kit
  • mail70 Sep 29, 2009
    The problem I'm refering to is that the picture intermittently goes to white foggy.
    President:
  • Mitsubishi Master
  • 1,779 Answers
Just search for the PTV Coolant, there's no such thing as a "KIT" for replacing fluid. You only need 3 bottles if your doing all 3 tubes.
Posted on Sep 29, 2009
How do you fix convergence on a sony tv?
hello!
If convergence in your TV went out suddenly and severely, there is nothing you can "adjust". That's a parts failure, convergence amplifiers I.C. chip(s) went south. Needs repair! Period! Minor alignments could be done by applying "flash focus" or "manual convergence" off "menu", if available.Some models have "flash" only option. Anyway, make sure there is no large metal structures near the front of TV or large speakers nearby. that could convergence to go out. Try not to play with any adjustments, if severe convergence problem. you won't be able to fix it right and will corrupt memory settings for "flash" option.
thanks,
Alex.
Feb 16, 2012 | Sony Televison & Video
Sony kp-43t90 picture looks like 3D what is the part # for the convergence chip?
Hi and welcome to fixya.
To answer your question;
Those convergence i.c numbers are STK392-150 .
But if you are into repairing your convergence circuit then perhaps i may have a suggestion,
It is very common to have resistors and/or picofuses burn along those convergence i.c`s, so just replacing the i.c`s may have little visible effect as they will be missing some the the needed operating voltages.
So you may consider buying a kit that would supply all the parts you may need along with instructions.
Here is a website that sells a kit for your model;
http://www.tvrepairkits.com/xcart/home.php?cat=1487
Note that i`m not working to sell any parts, just though that it may make your life easier.
Hope this help and happy holidays.
Dec 14, 2010 | Sony KP-43T90 43" Rear Projection...
Color will not match up
if your talking about the sets convergence does not line up and it looks like a 3-D picture than The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
http://www.fixya.com/support/r3342653-convergence_fix
May 08, 2010 | Hitachi 51UWX20B 51" Rear Projection...
My daughter pressed a button on the remote and the set went completely out of focus with mixed colors.
Ur convergence is dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The Shop will cost u $300 to fix for parts and labors.
Mar 17, 2010 | Toshiba 50H81 50" Rear Projection...
Fixing rca D52w26 convergence problem can you try fixing with remote
No,must replace parts,These websites,have convergence kits for many DLP TVS.Tv Repair
World.com,Tv Repair kits.U know how to solder right?
Oct 23, 2009 | RCA HD52W56 52" Rear Projection HDTV
My Hitachi 57 inch HDTV 57F500 model has a convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 03, 2009 | Hitachi 57F500 57" Rear Projection...
55" Phillips Projection needs coolant changed
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Mar 02, 2009 | Philips 55P8341 55" Rear Projection...
Double images with the red in myKP-51HW40
  • Screen looks 3D
Feb 18, 2009 | Sony KP-51HW40 51" Rear Projection...
Convergence Problem
  • Screen looks 3D
Sep 17, 2008 | Philips 55PW9363 55" Rear Projection...
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
