Question about Water Pik pik Original Shower Massage Sm 651
Unit dribbles and does not always pulsate,(waterpic original sho
Unit dribbles and does not always pulsate.
Unit has stopped working, checked brushes all ok motor moves freely ,no power
measure the contacts over the 2 coils of the electric field sometimes if there was a faltering powercable the pulsation from the coils was to heavy and then by the field the winding wire can also be broken important by broken wire on electric field , test in all cases always the power cord to stretch test
Mar 18, 2015 | Saws
FX SHO YAMAHA 2012. few hours, stops some times, at idle not always
Im not very agree either but i would tell them you have a lemon and want a replacement before they say too much time has passed.
Aug 14, 2017 | Boating
My camera always shoing memory full , i format the internal memory and format new sd card , same problem , still shoing the same , how can i fix it
Make sure that the camera is set to record to the memory card... often the internal memory will only handle a couple of pictures...
If it still shows memory full then a ribbon cable has come loose inside the camers and it is not recognizing the memory or cards...
heatman101
Apr 23, 2011 | Samsung NV3 Digital Camera
Power comes on but will not start wash cycle justs sit there and humms
Try the steps below:
- try running it without any load to see if it still hums.
- if it does, see anything underneath the pulsating disk if there's anything stuck. (like a coin or a pin)
- if it doesn't, You can also try removing the belt between the motor and the pulsator to isolate if it's a defect in the motor or the pulsator.
After that, If the motor is defective, then you'd have to replace that or repair it if you know how to. If the pulsator is defective, check again if there's something stuck in the bushings. If you've used the washing machine for quite a long time, you may need to replace the bushings and bearings of the pulsator. You can also buy an assembly unit for the pulsator if there's one available in your area.
Hope this helps.
Jan 27, 2011 | Washing Machines
Just installed a waterpic shower head, half the water comes out of faucet and half the shower head, any solutions?
If your tub spout has a knob that you lift to divert the water to the waterpic then replace it with a Delta service part #RP17453 pull down spout. It always sends 100% of the water to the shower head and will always snug tight to the wall.
May 24, 2010 | Water Pik & Wallmount Showerhead
I have a K3 78M electric unit . The motor pulsates
This sounds like an internal leak. If you are handy enough here is a schematic. On B@ it could be #25 is sticking or the valve inside #8 is leaking or the water seals #18 need replacing or #1 is leaking
Aug 18, 2009 | Karcher Garden
96 ford windstar
most likeley the front calipers are hanging up and heated up the rotors warping them. the cheapest way out is jack up each side of the van and spin each tire while someone slightly presses the brake to find out what wheel has a pulsation hesitation. then pull that brake caliper off and clean and re grease the gliders that alow it to slide back and forth and cut that 1 rotor. most likeley you will need to do this to both sides and replace the pads plus check the caliper pistons that they move freely. so to sum it up you might need a complete brake job.
Apr 30, 2009 | 1996 Ford Windstar
Anti lock brake system
If the light is not on it may not be the ABS that is pulsating on slow braking but it may be that your have warped brake rotors, even if the rotors were replaced with the pads the new ones may be warped already, we always check new rotors on a brake lathe before installing them because we have seen this happen many times
Sep 17, 2008 | 1996 Oldsmobile 88
Water Pik pik Original Shower Massage Sm 651 Logo
73 people viewed this question
Top Water Pik Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Water Pik Health and Beauty Expert? Answer questions, earn points and help others
