Question about Whirlpool 10 cu. ft. Chest Freezer EH101FXR
The red triangle shaped light on my frezzer is staying on and the freezer has defrosted its self is it fixable
5 Suggested Answers
  • 389 Answers
SOURCE: Maytag upright freezer with self defrost. The water line freezes.
This sounds like your defrost heating coil has gon bad. Not much you can do but replace it. Please leave a good thumbs up for me for the effort. Pretty sure I'm correct on this one. The Raz Shack
Posted on Apr 21, 2010
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
SOURCE: chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
Posted on Jul 18, 2008
  • 389 Answers
SOURCE: Exclaimation triangle red light is on - Electrolux CUU6174
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Mar 28, 2011 | Whirlpool Freezers
Frezzer is only 2 yrs old and already has defrosted on its own what seems to cause that?
This machine has an automatic defrost cycle that comes on automatically 4 times a day. During defrost the compressor goes off and the heaters inside come on and melt the frost from the coils. In about 20 minutes heat shuts off and compressor comes back on and freezes againl
Oct 18, 2010 | Continental Freezer Freezer display one...
Freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
May 05, 2010 | Hotpoint 4.2 cu. ft. / 119 liter Upright...
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Need to replace defrost heater in freezer
It could be the defrost time clock. if this is a self contained freezer the timer is kind of oval in shape their is a small hole with flash light should see some thing moving if not it's the timer you can turn adjusting stem until you hear it click that should put in defrost if you have an amp meter you can measure the amp draw should be around 2-3 amps or their is a klixon high temp limit is bad you likely need service. Tom
Jun 17, 2009 | Freezers
Red light on
have you checked if the fan is running in the freezer??
if not, check if fan connected to defrost thermostat, if it is suspect defective defrost thermostat but try the fan directly if it doesn't go on, suspect bad freezer f
Apr 20, 2008 | Freezers
Jan 16, 2008 | Freezers
Whirlpool 10 cu. ft. Chest Freezer EH101FXR Logo
115 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
