Question about Panasonic Video Cameras
Panasonic NV-DS5B Mini-dv camcorder shows F04 error which I believe relates to a tape loading fault. It is no longer possible to eject the tape but I would like to continue using the cam as a CCTV camera. My problem here is that it shuts down after 80 seconds from startup and either needs the eject button or the on/off switch to be used. Is there a solution to this problem or is it a product of the F04 error?
  • Panasonic Master
  • 5,412 Answers
It is probably shutting down because it senses there is no tape movement, to conserve battery power.
Posted on Jul 27, 2017
5 Suggested Answers
SOURCE: Connect Panasonic NV-DS27B Mini DV Digital Camcorder To PC ?
If you want to do the job properly for fully remote video editing, etc then you need a digital video capture card fitting into your PC and a firewire lead that suits your particular camera.
If it helps then I have the very thing for sale if your'e quick!!!
Martin :o)
Posted on Apr 17, 2008
SOURCE: trouble with finding Panasonic NV-GS11 Mini DV Digital Camcorder driver / software
NV-GS11
Posted on Dec 22, 2008
MNfisherman
  • 11896 Answers
SOURCE: how can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
Posted on Oct 14, 2009
SOURCE: i cant eject my Panasonic NV-GS55 Mini DV Digital video cassette
Try ejecting cassette whilst powered from AC Adaptor. Secondly, try operating Eject from powered off mode. If operation LED starts flashing after any of these attempts, the mechanism is probably jammed or has become mis-timed. Unfortunately this requires professional intervention to avoid further damage to your equipment.
I hope this information is of assistance!
Posted on Jan 01, 2010
NV-DS55B panasonic digital video camera.
Cylinder error (F05) usally caused by poor/oxidised contacts on cylinder drive fpc cable to pcb, sometimes caused by seized cylinder or drive.
The cylinder is the round thing that the tape wraps around that has the heads to record to tape, just in case you didn't know.
Aug 19, 2008 | Panasonic NV-DS55B Mini DV Digital...
Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
Apr 24, 2010 | Panasonic NV-DS65 Mini DV Digital...
I cant eject my Panasonic NV-GS55 Mini DV Digital video cassette
Jan 01, 2010 | Panasonic NV-GS55 Mini DV Digital...
Panasonic VCR NV-HD642 - F04 Error
You sound like you have a K Deck Model. If this is the case F04 means that the mechanism locks during unloading.
The apparent cause of this is the Load Motor timing.
Aug 08, 2009 | Panasonic Televison & Video
Exactly the same problem as everyone else. There's bound to be someone who can offer advice on what to do. The camera obviously recognises the fault as F05, but where can you reference the remedy to this F05 code? It's not in the manual as far as I can see
Feb 20, 2008 | Panasonic NV-DS55B Mini DV Digital...
Need help FAST!! Panasonic NV
remove battery for a while .put it again and try .if not works...remove battery agin then put it again by keeping power switch off. eject and remove cassette .take several eject operations. now try again.
Nov 04, 2007 | Panasonic NV-GS50 Mini DV Digital...
Problem with Panasonic NV-GS3 camcorder
use cleaning cassette , before a brand new blank tape ( may have a worn or damaged tape in your library ) ;
Jul 29, 2007 | Panasonic NV-GS17 Mini DV Digital...
Hints
it is general fault in this camcorder get a clean path tape and you may get better work regards
Apr 25, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Video Cameras Logo
158 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
