Question about Troy Bilt Tb70ss Gas Trimmer
Describe your troybilt tb70ss pull string Problem.
The pull string will not retract. I have repaired and continue to have problems. Is there a trick to rewinding the string?
    Problem Solver:
  • 13 Answers
Do you have mfg instructions? Can be very tricky without following instructions
Posted on Sep 29, 2009
TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Sep 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
The string on my Troybilt tb70ss just keeps coming out of the spool when I try to weedeat. I am pretty sure I have followed the directions. What is the problem?
there should be a small hole to put string in on center of spool.
you might be winding the line the wrong way around try winding line in other direction.
Jul 16, 2011 | Troy Bilt Tb70ss Gas Trimmer
How to get the fuel tank off the troy built Tb70ss gas trimmer
Go here and you will see the parts breakdown and diagram for this model...to give you an idea on the parts you will be working on:
http://www.ereplacementparts.com/troybilt-tb70ss-41adt70c711-gas-trimmer-parts-c-26780_27267_27463.html
Aug 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do you do you but the LINE in a gas fired weed eater troy built
The owners/users manual that comes with these units always explains this in good detail. Go here to view those pages in a Troy Bilt trimmer manual. You will need Adobe Reader. Scroll thru the pages till you get to the section on replacing the string.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb70ss.html
Aug 26, 2010 | Troy Garden
My weed eater wont start.
One of the problem could be is you have one of the line in this case top line in the carburator clog. For clean the carburator You need to remove first the cover for the filter 2 screws on front of the carburator remove lines mark the lines top and bottom remove slowly the carburator be careful with the gasket. The carburator have 4 little screws removed and remove the black gasket (diaphragm) clean with carburator cleaner and air, blow air thru the top line tube, now on the otherside remove the screw and clean the gasket and the carburator inside do the same step. Make sure you clean the fuel filter inside the tank with carburator cleaner.
Apr 05, 2010 | Troy Bilt Tb70ss Gas Trimmer
Pull cord will not retract
Have to take all 3 plastic covers (housings) off to get to the spring and tie the new pull rope or change the spring. Just did mine, spring just unlatched and string wouldn't retract. Did not have to by any new parts....works great! Took me 1 hour to get it done.
Sep 10, 2009 | Homelite 'Yard Broom' Leaf Blower
Pull string
Oppen the tray and change or put new suply of string
Vitally
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Starter pull cord
take a light and look into the clutch hole
you will either need a torx or star type nut driver or a allen or hex head nut driver to fit in the hole and turn the screw ccw while holding the flywheel.
Make note where all comes off and all goes back in reverse when fixed.also after you remove the clutch housing you will be stareing at the clutch shoes next and it will have markings on which way to turn it for removal.
Jun 01, 2009 | Troy Bilt Tb70ss Gas Trimmer
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy Bilt Tb70ss Gas Trimmer Logo
243 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
