Question about Cameras
Problem The circle thing to switch between viewing pictures is broken. It practically work. I cant go back, which makes it infinitely complicated when I have more than 2,000 photos. And sometimes its not turning on. Its all over the place, very fritzy. What can I, should I do?
4 Suggested Answers
SOURCE: CAMERA WON'T TAKE PICTURES?
the batteries are low. try replacing the batteries with new ones.or recharge the rechargeable batteries
Posted on Aug 14, 2008
  • 26 Answers
SOURCE: won't swich to view images
Mode selector switch needs replacement.
Posted on Jul 24, 2009
  • 2386 Answers
SOURCE: My Canon camera fell on
Hello
it shows that some internal damage has been occurred, need repair, recommended for repair from authorized service center.
Good Luck
Posted on Dec 20, 2010
MEW 7627A double ovens keep cutting out with a click and then turns itself back on again. The control panel has been replaced and it is still doing the same thing
Hello Sheryl;
My name is Peter. I am a retired field service appliance technician.
If your unit is new it should still be under warrantee for one year.
Who replaced the control board was it a service company? You should have a 90 day warrantee on the work, which did not work.
Anyway, you may have a bad; "Infinite Switch".
An infinite switch allows the user to set the heat from low to high and everywhere in between, hence the name "Infinite." This switch differs from a "Low-Medium-High" switch, which provides only three heat settings. The infinite switch uses a bimetal switch and physically moves through the process of heating and cooling, causing the main switch contacts to open and close and controlling the power applied to the heating elements.Typically, when an infinite switch malfunctions, the surface element will not heat, or it will remain on high in every position.
  1. Before repairs or testing can begin, you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!.
  2. Next, depending on your appliance type/model, access the infinite switch using one of the following methods:
    1. For most standard models, remove the back panel.
    2. On models with front-mounted controls, the panel is attached with screws on both ends. Remove the screws and tilt the control panel, being careful not to let the wires disengage from the components.
    3. For models with a removable backsplash, simply lift the backsplash, rest it on the cooktop and remove the screws to access the components.
    4. If you are working on an eye-level range or wall oven, remove the control panel by opening the door and removing the screws that secure it. The screws may be located under the front of the exhaust hood or below the control panel. If the control panel is hinged, tilt the control panel towards you.
    5. Some models will require that you remove the rear panel and front panel before work can begin.
    6. If the front control panel is glass, remove the screws securing the trim that holds the glass in place.
Test for continuity between the switch contacts:
  1. Remove all wires from the switch terminals. (Remember to label them!)
  2. Set the infinite switch on high and place your ohmmeter on the L2, H2, P and H1 terminals to check for continuity.
    1. If there is no continuity between L1 and H1 or between L2 and H2, the infinite switch is defective.
    2. If there is no continuity between P and H1, the indicator light circuit is defective.
  3. Remove the infinite switch by removing the screws or nuts that hold it in place and install a new infinite switch by following the disassembly instructions in reverse order. Be sure to follow the wiring diagram and install the wires to the correct terminals.
REMEMBER YOU ARE
Feb 16, 2015 | Ovens Ovens
50 inch LG Plasma tv picture wont work
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there.
Nov 14, 2012 | LG 50PX5D 50 in. Plasma HDTV
Can any one help me replace the infinite switch for the warming drawer on my GE gas range JGB920bec2bb Spectra XL44. Switch part number wb24k10006. Thanks. I think I need to remove the burners and top...
Hello & Welcome to FixYa
Please view this video to follow the step by step instructions in order to replace the infinite switch in your GE Gas range:
Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Kitchen Ranges
My GE profile electric range (model PS905SPSS) has a power boil burner with dual burner elements (one inner circle and one large outer circle). The outer circle one is glowing and heating but the inner...
Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
Nov 27, 2010 | GE Ovens
Canon powershot A520 doesn't work in camera mode. I can look at and edit pictures in viewing mode, but switching to "camera" won't let me take pictures... in this mode it also lets me view pictures already...
Hi!
Do other buttons work? If so, the switch could be broken because it sounds it doesn't switch to the CAMERA mode, just stays at the VIEW mode.
If you're not experienced in repairs, you should give it to a local repair shop or Canon service center.
Sorry for the bad news. I repair these cameras very often.
Tom
Sep 27, 2009 | Canon PowerShot A520 Digital Camera
Viewing photos on the htc touch diamond.
If you take lower resolution photos on the Diamond, especially photos for contacts, they aren't as big as the other photos, so you must zoom in for them to fill the whole screen. For that, simply do a half circle clockwise motion on the picture itself.
Also, if you took larger photos with the camera on it's side, you must turn it to it's side again so the picture goes back to landscape mode.
Jan 12, 2009 | HTC Touch Diamond Smartphone
CANON POWER SHOT SD750 DOESNT TAKE PICTURES BLACK SCREEN
Mine started working again. The only thing I can attribute to it is that I zoomed the lens in and out several times. The next time I turned it on, it worked. Go figure. I'll update if things change.
Dec 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Tmobile dash online pics issue/cant view anymore
open your internet browser on your phone go to menu-options-general and check and see if the download pictures is checked.
Oct 23, 2008 | T-Mobile Dash Smartphone
Intel (r) pc Cs630 tell me how i use this camera and take picture ????
Cycle with mode button -- HD is hi resolution, video icon takes videos. Push large oval button to take pictures or start video recording. Lens can be set to infinite focus at mountain icon or focused. Don't forget the on/off switch (circle with 1 in it)
Jul 17, 2008 | Intel CS630 Webcam
Broken flash
okay my holga flash was broken too....the batteries were working just fine cus when i turned it on, the little back light came on and the whining sound happened, but then click...no flash! so i took the back off and made a small repair and it worked!
so this is how to fix it (if its the same problem...i.e. everything electrical is working but the actual flash):
use a small screwdriver to remove the two small screws inside the camera (take out the frame and they are on the bottom and top). the front will pop off and you should be able to see the wiring.
where i circled in red was the problem. that curved metal piece at the bottom was too straight and was not making contact with the shutter (the top little metal prod sticking outta the circle) when i clicked it. so just bend it forward to how it looks in the picture...then do a practice click to make sure it makes contact. you can even try it with the batteries in, but be careful!! its electricity!
hope this helps!!
Aug 19, 2006 | Holga 120CFN Film Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
