Question about Roxio Easy Media Creator 7
IS THIS SOFTWARE SUITABLE FOR USE WITH SONY DVD RW
IS ROXIA EASY MEDIA CREATOR 7 BASIC DVD SOFTWARE SUITABLE FOR USE WITH SONY DVD RW AW-G170A DRIVE? I CAN ONLY RECORD ON CD-R AND CD-RW USING XP SERVICE PACK TWO OWN SOFTWARE.
PRESUME NEED ADITIONAL SOFTWARE OTHER THAN WINDOWS TO BURN DVD'S.
  • 4,806 Answers
Yes it certainly should be compatible with the CD/DVD drive.
Roxio has it's own burning software included with the program, you will just have to explore the software until you work out how to burn a CD using Roxio itself.
If you want to try another burning program try Nero 9 trial. All you have to do is enter your email address and then download the software. Nero is an excellent bit of software, i personally have never had any problems with it.
Get Nero 9 here >>>>>>>>>>
http://www.nero.com/eng/downloads-nero9-trial.php
Regards.
Posted on Sep 29, 2009
Sony dvd rw- aw g170a cannot read dvd rw
It is a burner.
With DVD burners you cannot read disks, only write to them.
This cannot be fixed
Jan 05, 2010 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
I have sony dvd rw aw - g170a but this drive is not working properly when i try play video cd directly into it. It do nothing. I have notice that in device manager there is yellow exclamatory! symbol. i...
The yellow exclamation point is telling you there is a problem with the device. First thing to do is uninstall the device using your hardware or device manager. Reboot. Your pc should automatically recognize the device on reboot and install the proper drivers. If not then you will have to go to the Sony website and download & install the drivers manually. If this does not fix the problem then your drive has went bad & will need replaced. Good luck & I hope this helps you out.
Jun 03, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Can not read DVDs by SONY DVD RW AW-G170A
I believe the read head is not aligned properly. I would send it back for a replacement. I have had this happen several time after the DVD burners/readers had many hours on them.
Dec 09, 2008 | Computers & Internet
SONY DVD RW AW-G170A BURNING PROBLEMS
It worked with Win ME but not with Win XP now
Aug 23, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
Problem with sony dvd rw aw-g170a
Hi i have Sony AW-G170A on 2 pc's and almoust at same period both pc's started not to read DVD cds, cds that were writen by the same drive so ive check the net and end up updating the Firmwares 1.71 to 1.75 so check this link. And get AW-G170A Firmware 1.75 then u gonna need Binflash to update the Firmware get Win32 GUI version if u use Win Xp. Open the program press Flash find the location of the 1.75 Firmware and update it restart pc and it should work it worked for me.
Jul 31, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
plz sum 1 gimme the link to download SONY DVD RW AW-G170A firmware.
Mar 28, 2008 | Computers & Internet
Problem
hi i am mohammed from india.
so u have dvd writer ?
while you buyed ur dvd drive. u may get a nero software cd.
u must install the nero application software. which support the dvd drive for the best performance of display, multimedia.
bye
Dec 24, 2007 | Sony (1-796-293-13) Plug-In Module DVD...
SONY DVD RW AW-G170a
This is a problem with the DVD Writer model. SONY DVD RW AW-G170a has problems reading DVD+/- R/RW Discs. But there is no problem with any of the DVD+/- R/RW Dual Layer, DVD Ram or CD+/- R/RW Discs. It is the reason that this DVD Writer lacks the correct bitsetting for DVD+/- R/RW Discs. There is nothing else you could do other than replacing the wirter with some other model.
Aug 01, 2007 | Sony (1-796-293-13) Plug-In Module DVD...
DVD RW - Installation Problem
Ok. What I am going to suggest may seem like a daunting task but if you are careful and do only what I suggest you should be ok. The first thing you are going to have to do is manually make a change to the Windows registry to fix the permissions. 1. Fix registry permissions a. Click on "Start" choose "Run", then type "regedit" and click "OK". b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine". c. Now click on the "+" next to "Software". d. Right-click on the key (folder) called "Roxio" and choose "Permissions". e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow". f. If you had to add those checkmarks, click on "Apply". g. Click on "Advanced". h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects". i. Click "OK". j. Click "OK" again. k. Now close the Registry Editor Next, you will have to uninstall the Roxio software. 1. Remove Roxio Easy Media Creator 7 a. Go to Start--->Settings--->Control Panel--->Add/Remove Programs b. Select Roxio Easy Media Creator 7 and select "Remove" c. Once the uninstall is complete, reboot the computer. 2. Reinstall Roxio Easy Media Creator 7 a. Insert the CD and install as you did before and then reboot. If you have any issues uninstalling the Roxio, go to the following link to download the Microsoft Cleanup Utility... http://support.microsoft.com/kb/290301 Run the utility after the unistallation attempt and then reboot and reinstall Roxio. Hope this helps. Good luck.
Jun 19, 2007 | LaCie 8x DVD+/-RW USB 2.0 External Dual...
Roxio Easy Media Creator 7 Logo
140 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
