Question about Kitchen Ranges
Red light
Hi what is the little button on the right hand side for it makes a little red light come on what is this light for ? thanks x
It is the top is hot it goes out when it cool
Posted on Sep 29, 2009
A friend has a Genie model H6000A garage door opener. The previous owners don't have a remote and I cannot find either a smart button or the little tags to toggle. Please help!
they'll need a new Genie Master Remote for that opener, and the learn button should be under the light cover on the right hand side. You should be able to see a red light near it.
Sep 15, 2013 | Building Materials
Have bought second hand mutsy stroller, no manual and no idea how to fold the chasis down!
First remove the seat or carrycot/car seat if this is on the chassis. Then, stand to the left of the chassis. Push down the button on the handle which lowers the handle bar height with your right hand. With your left hand, take a hold of the black cuff on the side of the chassis (this should be about waist height). In one movement, you need to pull the left hand up, whilst pushing down your right hand, this needs to be done at the same time, and with some force.
When the chassis is lowered toward the floor, this will click shut. To open the chassis, there is a small metal arm on the left hand side of the chassis with a red cover on (this is quite little) you need to lift this button upwards (towards you) and the chassis will open.
I hope this helps.
Nov 13, 2009 | Mutsy 4Rider - Red Stroller
I have a Sime Super 90 Combi Boiler. How do I start the pilot light? Thanks
does it have a little red button on the right hand side of the gas valve? if so you must put the gas valve button in the pilot positon and push it down and hold it, then click the red button {push it down} it will click and look at it keep clicking while holding down the button on the gas valve eventually when the gas gets thru it will light could take several clicks of the ignitor
May 18, 2009 | Water Heaters
Turn off Samsung U900 Soul camera shutter sounds
press the red button on the side to open camera mode> click the little menu button (this should be the right hand button when you use your phone normaly)> scroll across to the very last option (this should be settings)> click okay> scroll down till you find an option saying shutter> click okay> chose none and click okay to exit it.
if this doesn't work put your phone in silent/ meeting mode
Mar 25, 2009 | Samsung U900 Soul Cellular Phone
Fold and lock stroller
Hi! I have the same stroller as you do, the way to lock it once folded is, you should see a red plastic loopedy thing down by the front right side of the seat. This hooks onto that weird brown plastic nubb i'm sure you've seen on the right side of the handle.
Hope this helped!
Mattie
Mar 17, 2009 | Graco Quattro Tour Deluxe Travel System...
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
How do i fold a graco duoglider double stroller
do you see the red little button/switch thing on the handle bar? OK, put your right hand on the handle with your thumb resting on the little red button. Now with your thumb, slide the little red button thing in towards your hand (slide the red thing to the right). Still holding the button in, twist the grip of the handle bar (where your hand should already be sitting) away from you. if you can imagine giving a motorcycle gas, you would twist the handle back, right. Twist the opposite way for this. So, on the stroller just press the button in, twist the handlebar grip FOREWARD, give it a little push (think up & over) and the whole thing should just collapse down neatly. it should colllapse sown until you hear a click. this is the lock latching together to hold it closed. next time you need to open it the lock is located on one of the sides. all you have to do is release the latch which is also a bright red. should be easy to locate. hope this helped you out. if you need further assistance i'm mushroombunny@yahoo,com good luck.
Aug 10, 2008 | Graco DuoGlider 7924 Twin Seat Stroller
Hi...I have a w580i phone which is six months old....I put the charger in my phone & a red light flashed & now my phone will not charge or switch on....I hold the power button & get one red...
Hi
Please contact a skilled mechanic nereby and request him to 'boost up' the VOLTAGE of your handset's battery which should be minimum 3.2.
Thanks.
Supriyo DG
Jun 20, 2008 | Cell Phones
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
