Question about Craftsman Garden
How to remove blades on craftsman lt2000
I don't know how to remove the blades to sharpen them on my craftsman lt2000 lawn mower. Any ideas?
    Problem Solver:
  • 13 Answers
There usually bolted on from underneath you must have a wrench are set of wrench to take off. Most models are some times kinda hard to get to
Posted on Sep 29, 2009
How do I take blades off to sharpen them?
raise the mower put a block on the rim of the deck so the blade does not turn remove the bolt on that holds the blade in place sharpen and replace in reverse order
May 27, 2017 | Craftsman Garden
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
How do i get the blade off to sharpen it on a craftsman electric mower
I've never worked on one but it should be similar to a gas driven one. There should be a bolt or screw holding the blade to the shaft. Just unbolt or unscrew it, sharpen it and reinstall. Good luck...Lee
May 29, 2010 | Garden
Remove blades for sharpening on 17hp craftsman lawn tractor
i use a 3/8 drive impact wrench, the bolts are removed by turning them to the left, hope this helps and good luck
Nov 21, 2009 | Craftsman Garden
Craftsman LT2000 transmission won't engage
Sounds like you either lost a bearing inside the transmission or that something in the linkage system has come loose and shifted. easiest way is to jack the unit up and visually follow the shifting hardware, while having someone trying to engage it with unit shut off and see is you can visually find where the shaft is slipping or failing to move. Hope This Helps Don
Nov 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
1,330 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
