Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
I have an AquaLink RS One Touch. Problems with programming
I have an AquaLink RS One Touch. I have deleted all the one-touch programs. Now even when the pump is set to on it will go off as if it being controlled by some phantom program. Separately, can I just have 2 one touch programs, one that keeps pump on all the time and one that would be a vacation setting that runs pump 8 hours a day. Will that vacation setting stay ''on'' even when the program shuts the pump off after 8 hours (I don't want the normal setting to override the vacation setting unless I turn off the vacation setting and turn on the normal setting and visa versa. Thanks,
    Top Expert:
  • Jandy Master
  • 5,743 Answers
Make sure you don't have heat maintain on if on turn off
Posted on Mar 05, 2016
  • 22 Answers
SOURCE: Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Posted on Dec 30, 2008
  • 61 Answers
SOURCE: AQULINK CONTROLLER WILL NOT TURN OFF FILTER PUMP
Sounds like one of the relay's has gone bad inside the box. If your lucky you can move the wires to another relay if there is one available. Make sure you move the top wires too, not just the 4 bottom wires, or you will have to do some reprogramming.
Posted on Apr 04, 2009
  • 15 Answers
SOURCE: I have an Aqualink RS4. I want to delete the 3
The best thing to do is to clear the system memory. Aqualink can have a problem with "ghosting" Things just go on by themself when not programed to. A bad spa side remote can do that to but that is another problem.
To clear the memory
Push the menu button once
Push the back arrow to "System setup"
Push star * or enter button
Push back arrow till diplay says " clear memory "
Push star or enter
Push star or enter again to comfrim.
You will get a message "earsing memeory"
Now you can reprogram system
If you want differant run times like a summer and winter timing you can do that with the program groups
Hope this helped
Keith
Posted on Jun 23, 2009
  • 246 Answers
SOURCE: aqualink rs fault question
chage salt system
Posted on Aug 19, 2009
  • 128 Answers
SOURCE: We have the Jandy AquaLink RS PDA, we have two
If you have a spa side remote unplug it at the outside control panel. If the problem stops it's the remote
Posted on Aug 30, 2009
How to delete all current programs & reprogram
go to system set up then go to program then either edit or delete
Dec 18, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Erase a program jandy aqualink rs8
set up then to program highlight program and delete
Aug 04, 2013 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Can you use a pcb 6473 with the Aqualink RS PDA?
if you bought the motherboard with the PDA it is a PDA board no programming from the one touch you need a RS bezel board RS is for the onetouch you can control with the PDA but no programming with the PDA board you should be able to program from the PDA
Aug 07, 2012 | Jandy Pool & Spa
I want to know how to cancel a program on an AquaLink RS8
go into system setup find program then delete the one you dont want if using a all button just press cancel
Jul 15, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have an aqualink RS8, which controls the on/off timing of the pool/spa, fountain feature, solar heater and yard lights. 1 - the display reads "6520 rev hh" 2 - the spa has been turning on by...
first disconnect the spa side remote if they go away replace the spa side remote if they don't go away go to system setup and go to programs either cancel if all button or delete or edit if one touch or PDA
May 25, 2011 | Jandy Aqualink Rs4 One Touch Control...
How do I delete an Aqualink RS4 program? The filter is on all the time. When I set a new program start and stop time the controller keeps adding programs versus replacing an/the existing programs.
to delete a program go to system set up go to programs add or delete or edit if doing on its own disconnect spa side remote if goes away replace spa side remote if no spa side reset board clear memory and re program write down all auxs and JVAs
Dec 26, 2010 | Jandy Aqualink Rs4 One Touch Control...
AquaLink RS 4 top lights flashing red bottom lights flash yellow
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Apr 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
235 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
