Question about Cameras
When zooming camera it powers off - Cameras
Camera shuts down when i use the zoom.easy share c180
Using the zoom requires the motor which pulls more power than the camera when idle. If the battery is close to exhausted it will shut the camera off when you zoom. If this isn't the case your zoom may be stuck and the camera shuts down to prevent damage.
Oct 13, 2014 | Kodak EasyShare C180 Digital Camera
Should the lens stay flat or zoom out
What kind of camera do you have? Normally, if you turn on the camera, the zoom comes out and you can always unzoom it. Zoom should be flat when the camera is off. If the zoom stays out even if camera is off, it could be a power issue or you just need to charge the battery
Nov 22, 2009 | Cameras
Auto zooming on power up, intermittent problem
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Sep 28, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Wont zoom
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
Zoom is stuck
Just check the DC power supply flowing to the Lens block control. Some times the SMD fuse blows off and power may not reach the lens block motor.
Dec 02, 2006 | Sony Handycam DCR-PC105 Mini DV Digital...
Camera powers up but then shuts down
Check out this similar post - http://www.fixya.com/problems-solutions/t103765,p241282/Ricoh-Digital-Cameras.aspx In your case though, I would try to turn it on with playback mode selected on startup, to prevent the zoom from extending. This way you will know if the problem is connected to the zoom, or other mechanisms. In any case, if it's not a battery/battery door/card problem, you'll need to send it for repair, or find a shop that can handle it, and it's rarely a cheap repair. Good luck
Jun 19, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
