Question about Canon DR-2050C Path-Through Scanner
DR 2050C I have the Canon DR 2050C scanner and when i scann black & white documents (binary setting) it doesn't scann the colored (dark portions that are in the border) parts of the page. For example I have a document that has a one inch darkend portion (its green) of the left side of the page. The scanned copy omits the entire dark 1 inch portion but scans the rest of the page. So the page comes out 1 inch less wide. This is not a problem in the color setting as the green portion is scanned.
  • 490 Answers
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Posted on Mar 05, 2008
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Dr-2050c multi-page document stops scanning after one or a few pages, inconsistently. Feed lever is down in the multi-page position. Feeder tries to separate the pages: sometimes it succeeds. Document...
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Jun 08, 2009 | Canon DR-2050C Path-Through Scanner
Canon dr 2050c
i want the driver for canon dr-2050c
Aug 14, 2008 | Canon DR-2050C Path-Through Scanner
DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Jul 05, 2008 | Canon DR-2050C Path-Through Scanner
Grayblue Background on scans
A color scan will give real output as it is. If the background is grey, the output will also be grey. If you select 256 Color output, there may be small change in color, as compared to the original. If you select grey output, all colors will be converted to Grey. If these files are converted to PDF, it will be same, except in ODF format.
If you select B&W you can save the file in TIFF format. Unlike grey or color, each pixel can be either black or white only. To scan in black and white you must select right brightness. By doing os you can eliminate background (technically noise) and capture foreground(data)
S. Mohan
Oct 19, 2007 | Canon DR-1210C Scanner
Canon 2050C scanner
In the software, select 'multipage' option. (Check this box). The output will be collated and provided to you as a single file.
S. Mohan
Feb 08, 2007 | Canon DR-2050C Path-Through Scanner
Canon DR-2050C Path-Through Scanner Logo
273 people viewed this question
old marine
old marine
