Question about Averatec C3500 Tablet PC
Can't connect with internet . I think it has the wrong WEP key.
    President:
  • 2,600 Answers
If you think you don't have the right key, You can hold the reset button in on the router for 45 seconds and this will reset the wireless security, you will then have to connect the router to a computer so you can open a web browser window and reset wireless security setting for your network.
Posted on Sep 29, 2009
I have a 7 inch RCA tablet that will not connect to my WiFi the internet connect says it is connected but I don't have any bars so it will not allow me to go anywhere.
I've known some tablets not connect to the standard 2.4G wifi but are quite happy on the newer 5G wifi. don't know why.
I've also known some tablets only connect to WEP security or none.
see if you can change the security settings in your router.
Jan 30, 2015 | Tablets & eReaders
Zeepad jelly bean
when i tap on the "K" or "E" keys - they do not type. Is there something wrong with the tablet os is this something I can fix?
Jan 10, 2014 | Tablets & eReaders
New tablet will not go online
Have you checked that the tablet's ip address is not being blocked by your router or if you need to grant the ip address access
Dec 27, 2013 | Tablets & eReaders
I need help connecting to my wifi
You should be familiar with Android. Here's a general suggestion.
Go into your settings and go to wifi. There should be a check box or button there for changing between WEP and WPA. You should be able to make that change when you touch the scanned network you want to join. Your tablet should list every one it finds. If you already have your network selected, just touch "ignore" that network and start over again. Without knowing what version of android your using, it's hard to be more specific than that.
Nov 28, 2013 | Polaroid 7-in. Internet Tablet - Other
I just got a new tablet and need to learn how to connect it to the internet. how do i set up the wifi?
hello in your system you will find the built in wifi you will need to open this and search for networks most networks will have security like wpa or wep ,wep you can connect to ,look on the net for this program .....Netopia wep key depending on your location you will find alot networks .if you are planning on using a modem this can be easily installed ,via usb ,,,,,hope this helps you goodluck
Mar 23, 2011 | PANDIGITAL Digital Book 843967071153...
My Kindle (version 3) suddenly won't connect to my wireless network. I've re-entered our wireless passcode, but still doesn't work.
On a wifi connection when you see problems the cause will either be the device or the wifi router.
If you can try the kindle out on a different network this will tell you if it is the kindle or the network. If it connects then it not the kindle. It could be a setting or the router.
If it is a setting the two biggies are going to be something wrong with the security passcode or it isn't getting through the gateway out onto the internet. For settings you need to check things like using wep when it should be wpa or the wep key is 64bit when it needs to be 128 or in the wrong key location and so on.
When it can't get through the gateway that usually means your dhcp is wrong or you are using fixed ip. You can just set these numbers manually in the kindle.
The other usual suspect is that the router itself is beginning to fail. This usually shows up first as difficulty to connect and dropped connections or increasing errors. It will eventually fail. This is common and typical of all home grade wifi routers. They are good for about 18 months or so. If this is the case you might notice slow downs or dropped connections on other wifi devices. These units are not repairable so you just need to replace it.
Out of all the possibilities I would say your first choice would be the security settings and next would be the the router. Those are the two most common problems.
Feb 01, 2011 | Amazon Kindle Wireless Reading Device
How to connect wifi network in archos 28 internet tablet
This is normal. To save energy, the ARCHOS always starts up with the WiFi set to off. You must manually use the Fn-F3 keys if you want to activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong? Make sure that your WiFi is activated. This can be turned on and off with the blue function key pressed down and then the F3 key. The blue WiFi indicator just below the touch-pad will light indicating that it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong? It could be that the WiFi modem/router is hiding its SSID. This is done for security purposes sometimes. You can either change this on the WiFi modem/router (see its instructions) so that it broadcasts its SSID (and then you'll see it in the list on your ARCHOS 10) or you can go into the advanced settings of the Wireless Network Connection screen to the Wireless Networks tab and 'add' a new connection. You will need to know the SSID name and its other connection parameters.
Dec 17, 2010 | Archos 28 Internet Tablet
My wi fi is not connected. How do I do that/
I picked 1 up for the first time and connected in 2 minutes.
In settings page where you add a wireless connection, you will need to know..
Security type, mine was wpa2 ( may be wpa/wpa2/wep)
SSID, your network name that is transmitted, mine was default
password, whatever the wireless password you chose with wpa, if you have wep, it gives you a pass key, you will need to log onto your router to get this
Jul 17, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Can not get kindle to connect to wireless or whisper. so at the moment it still shows that the kindle is not regestered but has been register online
You may need to enter your wep key.
wep key is a wireless key code found in your pcs router,Go to the routers home page and look under wireless settings.Somewhere on the kindles configuration you need to enter this code.
Jan 07, 2010 | Amazon Kindle Wireless Reading Device
Averatec C3500 Tablet PC Logo
167 people viewed this question
Top Averatec Tablets & eReaders Experts
Are you an Averatec Tablet and eReader Expert? Answer questions, earn points and help others
