Question about RCA T25062 25 in. Combo
Tv wont come on
Water was spilled on it.
    Genius:
  • 1,148 Answers
Take the back off and check the fuses,, there probably blown,,good luck
Posted on Oct 05, 2008
Spilled some water on my phone and now my screen wont turn on. everything else works fine but the screen wont turn on???
Like all water damage on electronics, it is critical to do the following right away: (1).Remove the battery to slow down the corrosion process. (2). Have someone remove the case to expose the circuit board. (3). Assess the damage. It's easy to see where the water/moisture is as you should notice a whitish/greenish deposit at the spill site.
If it's minor, you might be able to clean the damage and resume operation. Good luck, hope this helps.
Sep 23, 2015 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
My Acer Chromebook wont turn on after a water spill
Power IC maybe damaged by water, try opening the whole system and dry the circuits and body and reassemble and try again, and well last option is always service center..
Mar 19, 2015 | Acer C720 11.6" Chromebook - 2GB Memory -...
Water spill on laptop
do a petrol wash to ur motherboard if den also it dosnt work den may be ur ic's or bios has burnt up try to go to service repair if den also it dosnt work den i m sorry u hve to get one new one.u should have to remove the battery immediately when water spoiled up
Jun 22, 2013 | Computers & Internet
I have a action replay and when I press start to play the game it wont load it just goes to a black screen. So then I tried my other action replay that I have and the game still wont load. Can any one help...
hav u recently spilled a little water on it? i did that n now i need a new battery or i need my dsi fixed if uve spilled water on it, n u tryed 2 start the ds right after u hav spilled water on it its gonna b fried so get new battery n try it out otherwise hav it fixed hope this was hlpful!
Jun 22, 2010 | Nintendo Video Game Consoles & Games
I spilled some water on my tv and now the sound is broken
Turn the TV off imediately. Remove the back cover and heat up the wet area with an hair dryer to thoroughly dry the board. Then try tv again.If it doesnt solve the problem look for the board that the speaker wires connect to and replace that board..You should be able to buy online.
Oct 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Grandson spilled glass of water on top of tv and it poured inside the tv. We let it set for a couple weeks to dry out. Earlier today it came on picture & sound but when channel was changed it went off....
Was the tv on when water spilled on it? Or on standby? I would guess it does not matter now. I do not like to even try to repair a tv with water damage...as the problem can go almost any where. Really and truly your best fix for headaches is to replace your tv. Some may argue this but I know best.
Sep 24, 2009 | Toshiba CF36G55 36" TV
Spilled water on it, now it wont turn on
Removed battery first. You should disassemble it to clean and wipe it dry. From bottom to top. Under its keyboard. Don't power it on until you are sure no water remains.
Apr 18, 2009 | Toshiba Satellite A135 Notebook
Spilling liquid on tv
Hello taboo_mac15,
I would advise you to check the TV fuse first to see if it has blown, if it has replace it with the same current (amperage) and voltage levels. If the fuse is not blown I would then suggest that you check the HV and deflection stages for damage.
You will need a voltmeter, a schematic, and a HV probe to do this job correctly. If you have these tools and some background in electronics, I will be able to walk you through the procedure to perform these checks however, If you do not have a background in electronics I would suggest that you get a qualidfied TV technician to look at this problem for you.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 19, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Spilled Water... where can I order new circuit boards?
Your Talking real expensive to replace the chassis in a projection. Was the Tv on when the water spilled? If it was only plugged in on standby it may be an easy fix. Do you have any soldering skills or troubleshooting experience?
Jan 13, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Tv broke
Spilling water on a TV voids the warranty. It is not safe to use. Buy a new unit.
Nov 07, 2007 | TruTech PVS2119 19 in. LCD Television
RCA T25062 25 in. Combo Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
