Question about Vivitar ViviCam 5100 Digital Camera
My pictures are fuzzy and have lines across them.
Bravia model KLV_40S200A. Why did picture suddenly become blurry?
If it is blurry and not fuzzy or with lines across the screen then I would suspect failure. See a repairman or Walmart! :)
Sep 10, 2015 | Sony Televison & Video
Fuzzy Display in bottom 2/3 of screen
Power supply is probably going out. Not likely the video card in this case.
Nov 18, 2012 | Viore " 24"" Class - LED - 1080p - 60Hz -...
White wavy lines going across my t.v
LG 26LX1D
Symptom
Wavy lines in picture
Repair
Replaced 2 bad capacitor's on the main board Location's C704 C708 1000uf 16V
http://tvrepairhelp.webs.com/lgjvc.htm
Dec 08, 2011 | LG 26LX1D 26 in. LCD HDTV
Horizontal lines across screen picture going fuzzy in and out and then no picture at all
A horizontal line that rolls from the bottom to the top of the tv could be a Hum Bar. This is from a bad ground either for the house electric system or for the cable system. By code, these grounds are supposed to be connected (bonded) together. In other words, the electrical interference is going through your tv instead of into the ground. Fuzzy picture is usually from low cable signal. This can be due to bad cables, connections, or splitters or problems outside with the drop (cable line outside that runs to the house). Splitters, by design, lower the cable signal (i.e. a 2 way splitter cuts the signal in half). If you have unnecessary splitters you should remove them. If you have more than about 6 or 7 tvs, you may need to add an amplifier.
Jun 25, 2010 | Vizio VF551XVT 55 in. HDTV
There are gray fuzzy lines across the pictures
Sounds like it could be cracked glass or a dirty lens. if its a cracked lens take it to a repair shop or buy new. if its a dirty lens whew! you saved some money just clean it off good luck please rate,
Rshutterbug
Aug 17, 2009 | Canon PowerShot A75 Digital Camera
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Tv turns on get piture then get fuzzy whit line then goes off pleaze help me
i had this same problem, there is a common fault with these models, and the onyl way to fix it is to get a chip replaced in there...cant remmerb the name of this, but it cost me about £30, now the tvs fine
Oct 31, 2007 | Televison & Video
Vivitar ViviCam 5100 Digital Camera Logo
96 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
