Mac lap top
The little mac lap top is virtually unusable. it happened realatively quickly from being fast and fine to a spinning wheel that cannot load and is sort of a freeze but can see stuff. 3 years old and no, I can not get to the finder or any of that, the wheel just locks into a spin
  • 33 Answers
You need to replace your HD.
Posted on Oct 06, 2009
Won't spin fast when fully loaded
You may have a weak clutch. If you can stop the washer during spin by hand, that's what it is.
Jan 26, 2014 | Kenmore 24422 Top Load Washer
The washer recently began producing a high pitch squeek during the washing cycle, and a louder than normal sound during the spin cycle.
The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
My neptune top loading washer will not spin out
This involves the spin lid switch
Twist timer very fast a few times and stop it on spin with the lid closed. Wiggle the timer to get the points to connect. Even if you
just get a little bump then its the timer.
If none of this works then it is the timer plus maybe something else contributing.
You can tape the two wires to the switch together and it'll work just fine
Also check the plunger on the lid to see if it is not broken off
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
My mac just wont start up. The little wheel that
maybe u not installed the system MAC Os properly or maybe your cd while installation has corrupted during installation.During this process u should not corrupting the installation.Or maybe ur computer MAC Os has a virus.I recommend u use kaspersky internet security for more protection...
Feb 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Whirlpool washer lxr9245eq1 doesn't spin dry completely
Try this... while in in spin turn your spin selector switch and listen if motor spins slower or faster.. at fast spin open your lid quick to see how fast its spinning.. check and make sure your drain line is cleared and the water flow out fast...and if its spinning too slow problem is in the gearbox area..
Jan 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Slow
Yes. With a typical default configuration you should keep an amount of disk space free on the C: drive as this is where your virtual memory or page file sits. When the computers ram fills up, the OS writes some of that memory to disk (virtual memory) so that it can free up real hardware memory (which is fast) for running apps. When disk space is restricted on the C: drive memory management becomes more innefficient as things need to be erased from memory and then reloaded rather than just swapped from the virtual memory on the disk. Worse than slowness if you completely run out of space your system will freeze up.
You should make sure your c: drive does not fill up. Also if you have another drive (such as a d:drive) with more space you can change where the virtual memory resides and place it there so that it can grow as it needs to.
Jan 08, 2008 | Audio Players & Recorders
Kenmore 44042 - No spin cycle
The front load washers are supported by springs on the top and shocks on the bottom.  More than likely you broke a spring on the top or cracked one of the shock mounts which causes and unbalanced load all the time.  Will it go through a spin cycle with no clothes is it?
Oct 17, 2007 | Kenmore 44042 Front Load Washer
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
