Question about InFocus LP 600 Multimedia Projector
Looking to replace the cable that connects the projector to the computer.
  • 2,236 Answers
Dvi to vga
Posted on Oct 21, 2009
Projector does not recognize computer
Hi Becki.
Projectors will usually be identified on your computer as additional or optional screens/monitors. Depending on your setup (laptop/desktop) you may have some alt keyboard buttons with icons for single/multi screens. You will also likely have monitor control panels or non-windows equivalents. In Windows, for instance, right-clicking the desktop will usually bring up a monitor properties page. There you may be able to then select if the projector is a mirror of your desktop, an extension, projector only, or computer only.
if the computer says it sees the monitor, then you'll likely need to toggle whatever sort of menus the projector has to select the input port. Looking through the manual (
http://www.hitachi-america.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/cp-x251_um.pdf ) , suffice to say that there are multiple ways to connect and, with that, plenty of ways to have your cable be hooked up and ignored nonetheless.
Hoping this helps!
D
Nov 30, 2015 | Hitachi CP-X251 LCD Projector
Colour dispaly problem in LP 640
are you useing SVIDEO out from your pcs video card to connect the image to the projector?
have you set your pc to send video out correctly?
It seems your pc is not sending correct video / settings wrong.
Or then there is a problem with the projector. Try a difrent input?
Mar 29, 2008 | InFocus LP 600 Multimedia Projector
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Computer cord
The type of cable you are talking about would be a VGA cable, heres a link to buy one online Comsol VGA cable HD 15 HD 15 5 moulded thumbscrews .
Apr 17, 2014 | BenQ PB6210 Multimedia Projector
I bought a usb-vga cable for my optoma widescreen 16:10 enhanced projector but its saying
hi sir,
try to switch the way of output, so that choice suitable screen output way.
certainly, it is possible with compatible problem. review your projector instruction, check it can support USB function or not by the manufacturer.
hope it is helpful for you.
regards,
Jack
flying200809@gmail.com
any friends who were looking for below products, welecome you to contact me,
Professional wholesaler and retailer: for below products
1) projector spare parts, such as color wheel, lamp, mother board,DMD. lens, etc.
2) computer mother board,
3) HP server, switch, router. Cisco router. switch etc. complete machine or asscessories or parts
4) server or router memory
5) GBIC OR SFP
Nov 29, 2011 | Optoma Office Equipment & Supplies
Can I use the speakers for my projectors
Generally, projectors don't have speaker inputs.
If you want to avoid an A/V receiver, connect the PC speakers directly to the DVD player.
Connecting a computer to the projector
Connect the projector to a computer using a VGA cable (included with the projector). In addition, you can connect an audio cable from the computer to the projector if you with to use the internal speaker of the projector. An optional USB cable connection is also available.
1 - VGA cable connection
2 - Optional audio cable connection
3 - Optional USB cable connection
Mar 21, 2011 | iSymphony W2 Audio Shelf System
I've connected the projector to my laptop using the VGA cable as stated in the manual. The projector reflects as it should, i can access the menu and input options which i then select RGB scart (though...
Not with any RGB input options, computers are not compatible with these. The projector needs to be set up to receive VGA. There must be a toggle button or menu entry somewhere on your projector that lets you do this or why would it have a VGA input?
Dec 07, 2009 | Sanyo PLC-XW55 LCD Projector
Projector projects red screen.
My take on this...if that pin was *shorted* to another pin in the connector and not just bent, you could be looking at a damaged video input section. The pins in the video connector consist of the 3 color signals(red--green--blue), their individual grounds, and syncing. If this has indeed happened, which is *VERY* easy to do, the projector must be repaired by a service facility.
May 05, 2009 | Dell 3400MP Multimedia Projector
Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Connecting Projector to High Def Source (e.g. PS3 HDMI)
That projector supports M1-D also which is the digital side of the M1-DA... Anyway, they sell cables that are M1-D to HDMI to which you can hook directly to the PS3. They are decently priced too, less than $20. I know this thread is old, but I came across it due to an issue I am having with my xb31, broken color wheel. Trying to find parts...
Feb 06, 2008 | HP Digital Projector xb31 Multimedia...
InFocus LP 600 Multimedia Projector Logo
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
