Question about Samsung Televison & Video
Samsung TC9885TB When I turn on the TV it is stuck in VIDEO mode on one channel. The remote won't change channel and the tv buttons won't change channel. I even unplugged the tv for an extended period of time and plugged it back in and it is still stuck on that channel. What do I need to do in order to be able to change the channel. I do have the original remote. Thanks!
Benimur
  • 6966 Answers
SOURCE: SWITCHING FROM TV MODE TO VIDEO MODE
Hi, If the AV button is not in your remote, then perhaps it is part of the Ch up/down buttons - meaning right after your last programmed Channel would be AV before the first program Channel. Although I have yet to come across such a case, I have worked on units/remotes that have this feature of the AV included in the channel memory. Good luck and kind regards.
Posted on Aug 20, 2007
SOURCE: Philips tv turns on by itself and is stuck in demo mode
Change the eeprom
Posted on Mar 17, 2008
SOURCE: TV Stuck in TV Guide Plus+ Installation Mode
None of the above worked for me even with the original remote. That installation message will keep repeating if the cable line is not directly connected to the tv (the message and tv will flicker with static which means it's flipping through each channel about 120). I disconnected the line from the comcast box and put it in the tv and let it flip through all the channels (it had picture this time and no static once the line was directly in the tv). I then turned the tv off for 2 hours and the installization was done.
Posted on Jun 03, 2008
  • 11 Answers
SOURCE: No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Posted on Sep 13, 2008
SOURCE: TV stuck on Video
I had this problem, I replaced the remote and it works now
Posted on Nov 03, 2009
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
Won't channel up and down, stuck in input mode
Good morning Cheri
try restarting the tv, just disconnect all electricity for 30-60 sec.
connect again. If that does not work, Try set- up on the menu, if you get the apparatus to obey you and leave the input mode.
If that does not work I always restart the router and "exchange"box,
enjoy your day
kolbrub
Mar 25, 2014 | Sanyo DP50749 50 in. Plasma TV
The colours on my tv screen are all green and distorted can you tell me what the problem is its a samsung and its only 2 years old
YOU MAY HAVE CONNECTED THE RECEIVER TO AN INPUT ON THE TV THAT IS INCORRECT FOR THE SIGNAL OUTPUT FROM THE RECEIVER.
GET YOUR TV BACK ON THE CORRECT INPUT OR CHANNEL...CYCLE YOUR TV THROUGH ITS INPUTS BY...PRESSING THE INPUT, SOURCE, OR TV/VIDEO BUTTON ON YOUR TV REMOTE OR THE TV ITSELF.
IF THE PICTURE IS NOT RESTORED, CHANGE YOU TV TO CHANNEL 3 OR 4 USING TV REMOTE OR THE TV ITSELF.
IF THIS IS A 2ND TV, TUNE YOUR TV TO CHANNEL 60-73 USING THE BUTTONS ON YOUR TV REMOTE OR THE TV ITSELF.
ONCE YOUR TV PICTURE IS RESTORED, PRESS AND RELEASE THE SAT MODE BUTTON ON YOUR REMOTE TO ENSURE YOU'RE IN THE PROPER MODE FOR CONTROLLING YOUR RECEIVER.
YOU CAN ACCESS YOUR FEATURES, SETTINGS ETC, ON YOUR MENU BUTTON ON YOUR TV REMOTE.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Samsung Televison & Video
Sanyo TV 27 inch stuck on Video mode. It reached this mode by me pressing the input button on my (GE) Universal remote, not knowing it would put it in Video mode and then accidentally pressing enter to...
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
Jan 20, 2011 | Sanyo DS31520 31" TV
How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
Change TV channel on SAMSUNG DVD-VR350
Hello Giancarlo, You'll have to use the projectors remote for T.V. tuning. I don't think the samsung DVD remote will operate your projector or your T.V. channels, will it? If it does, You just have to switch the input button on the remote to change between T.V. and Video. I hope that helps.
Jun 02, 2017 | Samsung DVD-VR320 DVD Recorder/VCR
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Video mode
I went to add/delete channels in my menu on my symphonic and it let me scroll through the channels, make sure you have them all set to add (by pushing the volume buttons to make them light blue instead of purple)....after adding all of your channels (or just the one if you use dish) just power the tv off while on a channel and then power back on and you should have tv.
Jan 12, 2008 | Symphonic ST419E TV
Tv is stuck in video mode
The best thing to do is get an original replacement remote and then you will absolutely be able to enter the menu and perform the autoprogram.
Aug 23, 2007 | Sanyo DS27820 27" TV
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
