The battery is charged, but my camera keeps turning off and on for no apparent reason. I have not dropped it or exposed it to water. I've had it for 3 years, so I'm wondering if the battery is just bad???
Try using a liquid contact cleaner. I read about this fix on another site, worked great for me.
A product called DeoxIT in the U.S. is what was suggested, I am in Canada and can't get that here so I picked up a product from a company called NexxTech. Just a liquid contact cleaner.
Take out the battery of the camera. Put a few small drops of the contact cleaner on the power button and let it drip down into the switch. Rotate the on/off switch back and forth 5-10 times, put the battery back in and Voila! Fixed!
No more random on/off irritations, camera works just like it did before the problem arose a few weeks ago.
It worked great for me.
Good Luck!
I am having the same problem. Do i have to take apart the camera to get to the power switch or just let the solution run down through the shutter button and the power switch?
This fix should only be done by a professional or one who is familiar with repairing electronic devices. I have fixed many Kodak camera's with exactly the same problem.
Inside the camera the lens is attached to the circuit board with a ribbon cable and it inserts into a connector that it's latch can pop open if the camera is dropped or Jared. The way to fix it is to remove the back and re snap the connector. I have fixed many this way. There are two hidden screws behind the eye piece. Press down on the eye piece after removing the screws on the bottom. Be very careful where you touch on the circuit board. In the upper right corner is where the high voltage is for the flash. That can cause a nasty shock if you touch it. Even if the battery is removed it holds a charge.
I have exactly the same problem with my p850 (unexpectedly turning off and on).... I was wondering if trying a new battery solved the problem for you?
Same problem here, Recently started happening.
I have 3 batteries, used in rotation. This does NOT seem to be a battery problem.
I am having the exact same problem, camera is a few years old, never abused, worked two days ago fine, now when I turn it on, it shuts off, then turns itself back on, when I take a picture it shuts off then turns back on.
I have the same problem. Camera has never been dropped, abused, etc.
I purchased 2 new batteries and problem occurs with both of those as
well as the old original battery. Seems to stay powered on after
several minutes of cycling off/on. Maybe the power supply "warms up"
or something? I have also tried cleaning the contacts on the battery
and inside the camera with no change.
Have the same problem. Cleaned battery terminals. Batteries fully charged each time. Also camera was serviced one year ago. Believe the problem lies in the on-off switch. Maybe poor contacts inside switch. I don't have an answer, but I believe Kodak produced a miserable piece of **** because I don't see this problem happening with Canons, Olympus, Sony. or Fuji's. Maybe Kodak can do a free repair job on these switches if this problem becomes more prevalent. Then it becomes a manufacturer's defective part. Harold
I had the same problem with the camera turning off, and on again...several times. I am almost postive it was in the on/off switch. I had purchased an extended warranty and after a few other issues...mostly because I dropped in a few times...I sent it in to be repaired. After it came back, I no longer have an issue. So, I am confident to say it is not a battery issue. I have more than one anyway...and the problem happened regardless of the battery. The repair was either in software, or mechanical.
I started having the same issue described above yesterday:
the camera is a 3 years old, never abused, worked up to now fine, now when I turn it on, it shuts off, then turns itself back on, when I take a picture it shuts off then turns back on.
It is the power switch maybe since I tried with no battery on my docking station I also have the DC 5 V adapter and tried with no battery - still the same.
Very frustrating problem - please help me solve it without any service since they have no Kodak official service in Bulgaria and the camera is out of warranty. Anyone who has fond any solution?
