Question about Lands Phones
How to open a phone handset
I need to open the handset to repair it. I don't see any screws and I tried to unclip it, if it's hold by clips. I was not succesfull. Is there a trick?? Thanks
icansurf
  • 72 Answers
SOURCE: how to open the handset
look for hidden screws under stickers, nameplates, etc. carefully pry open the case at its seam
Posted on Mar 03, 2007
there are two screws in the bottom back of the phone only. when I open them, the bottom side will lift up, but the upper side (anttena and LCD direction) is still sticked.
Posted on Mar 06, 2007
SOURCE: open handset for KX-TGA571A
I had a similar mystery with
Posted on Aug 12, 2008
SOURCE: The clip that holds the handset in place came off
The clip has sliding fit,try different angle to slide in if its not chipped or broken.
All the best
Posted on Mar 22, 2009
SOURCE: need to open handset for
After taking out the two screws from below the battery compartment, the case will separate slightly on the bottom. Take a screwdriver and carfully pry the case open along both sides, working from the bottom toward the top of the handset. This will free the back of the handset from the primary components. It will simply snap back together when done and then replace the two screws.
Posted on Feb 06, 2011
I have removed all the screws but cannot separate the two halves. What else must I do to disassemble this?
make sure all screws are out first. the 2 halves are held together with clips. they will be hard to pull apart. try and make a small opening with a knife between the 2 halves and work around untill you come across a clip, push down on the clip to release it . there will be a few holding them together and you might find if you unclip one and move on it will clip back into place so a few thin instruments will be needed all the way around
May 01, 2015 | Tools & Hardware - Others
Tip
Mazda 5 SUV/van brake light assembly replacement
This is easy and takes maybe ten minutes. You need a phillips screwdriver and a pair of pliers. Open the hatch and remove two screws at the back of the brake light assembly. Pull the light assembly hard straight backward until the little pop-clip holding the front end of the light lets go. (This is the hard part, because there aren't any great places to grip the light and the front end pop-clip is stubborn.) Then unscrew the bulbs from the broken assembly (don't touch the bulbs or the slight oil from your fingers will make them explode when they heat up - use surgical gloves if you think you can't help handling the bulbs). Gently remove the wiring harness from the NEW light assembly and discard it. Push the existing wiring harness into place in the new assembly and screw the bulbs in. Line up the assembly's pop-clip to the front end screw that it pushes onto, and push hard from the back until it pops on. Have a helper lean into the light from the side to line up the two screw holes at the back, and put the screws back in. Use a pair of pliers to unclip the rear baffle from the broken light (two clips), then pop the baffle onto the new light.
on Jun 07, 2015 | Mazda Cars & Trucks
How to open nokia n73's parts
In order to disassemble a Nokia N73 phone first of all you need to remove the battery cover (back cover) of the phone. Then remove the battery, memory card and the SIM card.
Pry up the front cover frame by using the safe open pry tool. It is recommended to start from either of the bottom corners of the phone. First insert the safe open pry tool between the cover and the keypad of the phone to unhook the clip underneath. Do not apply too much pressure as this may damage the front cover. You can use Triangle Safe Open Pry Tool in conjunction with Safe Open Pry Tool for prying up the cover frame safely and conveniently.
Do the same to unclip the clip from the other side. Once you have undone the clips, run the tool gently along the sides of the cover to unclip all the clips. This should remove the cover without much difficulty.
Now you need to remove the display shield which holds the LCD screen in place. You need to pry the display shield up using the safe open pry tool to unlock the clips holding it in place.
Once you have the display shield removed, the next step is to remove the LCD which will now be loose enough to be lifted up. Gently lift up the LCD using the safe open pry tool but be very careful as you still have to remove a ribbon cable to be able to free the LCD. To disconnect this cable you need to gently lift it and it will pop out.
Once you have disconnected the ribbon cable, the LCD can now be lifted up and removed. Your Nokia N73 is now disassembled.
Reverse the instructions above to reassemble your phone.
Please let me know if you need more assistance.
Regards.
Nov 03, 2011 | Nokia N73 Cellular Phone
How do I remove the clip holding battery in place on a geneva watch?
That clip is called contact. You have to unscrew the screw(s) holding it. If there are no screws, poll the end of contact to the side with tweezers till it gets unclipped.
Feb 25, 2011 | Watches
How To remove the cover from Samsung SGH M-200
To remove the cover of the phone, you follow the process below:
Remove your back cover by pressing down the black part and sliding it downward, remove your battery and sim. Two screws need to be removed,
There are four slots in battery compartment. Two are by the left side and there are two opposite. Push a mobile phone opening tool into each slot and then turn it. This will release the clips that hold the battery compartment in place, now you have the back cover removed
Next release the clips that hold the front cover,
Just gently unclip the hooks that clips the front cover, there are about 6 hooks by the sides, 3 on each side, now you have both back and front cover removed.
Take care and good luck
Oct 14, 2010 | Cell Phones
The rear wiper on my 99 Bravada has quit working. It made about 2 passes over the window before it completely stopped. How do i go about replacing the rear wiper motor?
Unscrew inside panel on tailgate (3 screws-1 each side, 1 in the middle), unclip and remove by pulling up and out towards the rear. Unscrew all screws holding steel plate down, unclip plastic clips that hold the rod running behind the plate and unhook rod at top of that opens the window. Unclip wiring harnesses, remove wiper from the outside (1 nut holding it down)and unbolt the motor. It is pretty self explanatory once you have the steel plate removed, just remove and install the screws and clips in the same order and try it out before you put all your screws back into the steel plate since there are so many. Back window must be closed for wiper motor to work. To save yourself from replacing the motor with a new one, 9 out of 10 times it is simply the locking washer has come off of the gear inside the motor, if you pop off the plastic motor cover you will see the washer is off the gears are out of place. I realigned the gear and replaced the washer with a "C" clip and it has been working great for over a year!
Dec 08, 2009 | 1999 Oldsmobile Bravada
How to remove the screen on a sliver 7 model
It's a little fiddly:
1) Remove the battery cover
2) Remove the 4 screws on the transceiver board
3) Unplug the 2 flex cables, coaxial cable and earpiece cable from the board.
4) Remove the transceiver board
5) Remove the rubber plug and antenna cover from the rear lower of the handset
6) Remove the 2 screws under this cover
7) Carefully unclip the bezel from the phone and remove it
8) Unclip the 6 clips holding the display bezel in place from the back of the phone - you need to use a thin screwdriver in the 6 slots (4 of them are under where the transceiver board was, the other 2 are in the batttery compartment.
9) Lift the display and frame away from the chassis.
When reassembling:
Make sure the keymat is correcly located on the pins on the front bezel
Ensure the earpiece cable is in the right place, and not trapped.
Be careful reattaching the cables to the transciever board - they are both small and fragile.
Sep 27, 2009 | Motorola Mobility SLVR L7 Cellular Phone
How to Replace a rear Windshield Wiper Motor
Unscrew inside panel on tailgate (3 screws-1 each side, 1 in the middle), Unclip and remove by pulling up and out towards the rear. Unscrew all screws holding steel plate down, Unclip plastic clips that hold the rod running behind the plate and unhook rod at top of that opens the window. Unclip wiring harnesses, remove wiper from the outside (1 nut holding it down)and unbolt the motor. It is pretty self explanatory once you have the steel plate removed, just remove and install the screws and clips in the same order and try it out before you put all your screws back into the steel plate since there are so many. Back window must be closed for wiper motor to work. To save yourself from replacing the motor with a new one, 9 out of 10 times it is simply the locking washer has come off of the gear inside the motor, if you pop off the plastic motor cover you will see the washer is off the gears are out of place. Just realigned the gear and replaced the washer with a "C" clip and you just hopefully saved your self some money. Good luck friend and hope this works. keep me posted, be glad to answer any question you may have.
Jul 02, 2009 | 1998 GMC Jimmy
All the best
Mar 22, 2009 | Panasonic KX-TG2770S Corded Phone...
Changing housing on Nokia E65
Hi I have just changed my covers, it is in three parts front, middle and battery cover, first have a good look at your new parts to see where they clip, remove battery and sim, remove the front cover by unclipping it, remove the 4 screws on the back, on the front down the side of the lcd push and slide out the guide rails, watch the small rubber washers at the top and the plastic spacers at the bottom do not get lost, the front can gently be removed watch out for the spring catch that connects the front to the main frame and unclip from the post on the front, open the front just enough to gain access to the one remaining screw holding the middle section, unclip the circuit board at the bottom from the middle frame, prise out the connector bar along the side, watching nothing is catching your frame should come apart, I kept hold of everything in one hand while gently removing the mid section frame that way I did not have to disconnect any of the connectors, clip out the buttons from the side of the old mid section and replace in the new one, then work backwards to reassemble, I had never stripped a phone before but mine is now perfect with its new covers, just take your time and reason it out
cheers
andy
Sep 24, 2008 | Nokia e65 Cellular Phone
Lands Phones Logo
693 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
