Question about Refrigerators
About 1:00 am this morning our fridge tripped the circuit breaker, it ha never done this before. I reset the breaker and it tripped 5 mins later. I left it unplugged for the rest of the night. I plugged it in about 12 hours later and it tripped as soon as the plug touched the outlet. can you help THANK-YOU Lorne
    President:
  • Refrigerators Master
  • 1,922 Answers
Lorne:
It could be the compressor,contactor/overload,main control board bare wire,shorted defrost bar or control, have some one check the plug with an ohmmeter and see just how shorted the unit is
Posted on Nov 04, 2009
  • 308 Answers
It sounds to me, either you have a bad circuit breaker (the breaker itself); or you have a bad motor or compressor in the fridge. If possible try plugging the fridge into a different outlet. (If you use an extension cord to do this, make sure it is a thick gauge, in order to not cause an increase in amps through the smaller cord.) This should tell you rather quickly if the problem is with the breaker or the fridge. If it does turn out to be the fridge, you will probably find it is cheaper to replace a fan rather than the fridge, but the compressor (including installation) would probably cost more than a new fridge. (depending on how "fancy" it is)
Hope this helps
Posted on Sep 29, 2009
Actives art fridge/freezer tripping mai circuit breaker, been running since 9.30pm, and tripped it out at 9am this morning
get in a technician as there may be a problem start/run capacitor that has overloaded and tripped the breaker or a compressor failure
Mar 19, 2017 | Refrigerators
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
Maytag fridge trips circuit breaker
replace the ptc overload relay on the compressor,it merely unplugs,it supplies start and run power to the compressor and if its bad it will allow the compressor to operate on the start windings too,and draw a lot of current
Apr 06, 2010 | Refrigerators
The refrigerator trips the circuit.
possible failed start /run capacitor for the motorm
call a technician for a proper diagnosis
Oct 06, 2017 | GE Refrigerators
Soleus mac 12-k air conditioner runs for 45 mins then trips breaker. i reset and then 20 mins later shuts off again.
first of all an amp reading needs to be taken to see how many amps the AC is drawing. It may be too much for the breaker. Also see what else may be wired in on the same circuit, there may be additional load on the breaker. If all amp readings are below the rating for the breaker then you may have a faulty breaker, but that's pretty unlikely. The most probable cause is you are overloading the circuit.
Sep 14, 2009 | Soleus MAC-12K Air Conditioner
Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Oct 14, 2007 | Kenmore 62602 Electric Dryer
Refrigerators Logo
410 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
