Question about Brother MFC-7220 All-In-One Laser Printer
The system says that the rear door is open but no matter how many times I open and close it the message still appears. Is there another rear door that I don't know about?
    Champion:
  • Brother Expert
  • 265 Answers
The sensor for the back door is directly located on the underside of the motherboard. Check whether the sensor is dirty or else you might have to replace the motherboard.
Posted on Dec 11, 2009
    Problem Solver:
  • 4 Answers
Sometimes there is a small bit of paper stuck in there, or even a whole sheet, so check for a paper jam there. Always press start after clearing a jam, especially if you have to open the front cover, remove the drum and put it back in. I found that removing and reinstalling the drum solves a lot of print problems.
Posted on Oct 06, 2009
2007 yukon xl lift gate unable to open
try open the left back door first then the outher one
Jan 03, 2014 | 2004 Chevrolet Suburban
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
Sep 30, 2012 | Chevrolet Vehicle Parts & Accessories
Brothers Printer MFC 7420 Error Message "Back Door Open" I opened it and closed it several times still getting message. I unpluged it andtried again. Help
Hi. You have to follow these steps: Be very careful:
1. Open front cover, like in this image:
2. Pull out your printer's toner cartridge & drum unit:
3. Open back cover
4. Pull the tab which is in front of you in order to open the rear chute cover.
5. If there is any, pull the jammed paper out of the fuser.
6. Close back cover and put the cartridge toner & drum unit back where it belongs.
7. Close front cover too and see if it works! If your error will still appear, try powering your printer OFF & ON
I hope I helped you!
May 20, 2011 | Office Equipment & Supplies
We keep getting a message -paper jam check open rear door. checked, no paper jam, opening and closing rear door will allow the print job to go through. It will work for a few print jobs, then the same...
It's probably a sensor on the fuser. There are 2 and sometimes they get stuck and just closing the rear door hard will release it. Replace the fuser.
Dec 08, 2009 | Dell W5300N Laser Printer
Printing starts..then stops when paper is just appearing.
Replace the exit sensor clipped into the moulding above the fuser. (Very Common)
Mar 26, 2009 | Samsung CLP 315 Laser Printer
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Dome lights intermittently flash on and off in a 1996 Jeep
If it has automatic or a domelight that stays on for a while after you shut the door is on a timer relay and that is probably getting bad. As far as the door ajar message there is a switch in the door jam, look and see if you see it. Take wd40 and try to soak the switch try to get it inside the switch.If its incorporated in the door latch spray back inside the door latch real good. Open and close the door several times and see if it works then.
Nov 24, 2008 | 1996 Jeep Grand Cherokee
Error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Jan 07, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
Brother MFC-7220 All-In-One Laser Printer Logo
110 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
