Question about Mitsubishi VS-5043 50" Rear Projection Television
50" rear projection TV
Horizontal lines alternating between up and down
Present on t-Vo recordings, DVD's and TV shows.
  • 4,402 Answers
This is a VZ3 chassis50....notorious for cracked solder connections on the yoke plugs. Look at each yoke on the 3 CRT necks , you'll see a Molex plug on each yoke. The top two connections are for the vertical winding. There is a plastic tab that hinders easy soldering of these....carefully clip it off with a good pair of ****. You can then access the top 2 solder connections. Resolder these and also resolder the vertical output IC401. This should take care of the problem.
Posted on Dec 21, 2007
I have a 5 year old hln5065w tv which has been making a noise seemingly coming from the fan for 6 months without any picture problems. Now it has horizontal fine lines constantly going upwards, as if the...
Noise is your Color Wheel and Bad Capacitors in power supply will cause Lines if you see any that are swollen,vente or puffed up on Top they are Bad
Go tyo Encompass Parts Distrubtion and type in your Model Number it will list Part number for Color Wheel and if they have any in stock 1-800-638-3328
Jun 26, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP53S25 rear projection TV - Horizontal lines on display
try this link
see this link and try to understand the blink codes.
this will surely help you
May 31, 2009 | Philips 60PP9202 60" Rear Projection...
Screen gets horizontal lines and jumpy screen.
Your problem is capacitors CP204 and CP205 by the 9 volt regulator on the main board. Cp204 is a 47 microfard @ 50 volt and the other is 100 microfard@ 16 volts
Nov 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Have power but no sound or picture
Do you have high voltage? Check by turning up one of the screen controls to see if you have retrace lines.(pinstripe diagonal lines across the screen) If present turn the screen control back down until the lines just disappear. Check diodes 6003, 6012, 6025, and resistor 3669. If you don`t get a retrace line by turning up the one of the screen controls, check for missing voltages or shorted components in the horizontal output and power supply circuits. Note: Philips TV`s can be tricky even for experienced technicians. Good luck
May 22, 2008 | Philips 50P8341 50" Rear Projection...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Black horizontal lines on mitsubishi VS-5043
Is the noise in all inputs (line, tumer) ? If it is in the tuner alone, check the coax lug to see if you knocked it loose. This could be the problem. Check you picture with a DVD player on the Video input. Let me know what you find.
Jul 03, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Horizontal grey lines on TV
Sound like you have to turn down the G2 (screen)controls. They are turned up too high.
Jan 01, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
