Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Smell Hi, We recently installed Fahrenheat model #F2546NWC in our den to supplement our central furnace because the room is on a slab.  It replaced another baseboard heater that made too much noise.  This new heater is quiet, but there's a smell emitting from it that's not going away.  It's a strange heat smell, and we can't stay in the room too long because the smell gets to us.   Is this typical?  Will it go away?  Is it defective?
  • armandoara Dec 21, 2007
    we have the same problem. I read in the instruction booklet that the smell should go away after an initial blast on full power for several hours. I did this but the smell has not gone away. with persistent coughs and ill health, we are starting to wonder if the smell is the cause?!
  • Anonymous Jan 21, 2008
    My Fahernheat baseboard heater is a 110 model with no noicable numbers on it. I took it back to home depot however i did not have my receipt and they told me I needed to contact the manufacturer to address the problem. The unit began smoking and smelling like buring wires and when we moved it to another location to obseve it better it stared on fire.
  • 625 Answers
The heat may be affecting the unit's paint. normally the oil used in manufacturing burns off the first time the unit is used. maybe the proximity of the element to the case is too close.
Posted on Jan 10, 2008
We installed fahrenheat f2546nwc baseboard heat and when we turn it on it smells like something is burning, maybe plastic. we have a honeywell thermastat , not sure how to tell if its double pole or if...
Sounds like possibly you haven't removed all packing material. All machines will produce a strange odor upon start up but should go away rather quickly. Be sure to Read the manual in it's entirety
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 02, 2017 | Fahrenheat F2543 Baseboard Heater
What thermostat do I use for a model f2546nwc heater where the thermostat is mounted on the heater
u have to use a double pole thermostat...u can find it a homedepot...it has 4 wires- 2 red and 2 blacks..i just installed mine on 11/7/10...
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
Chemical smell
Might be Plastic part is Melting due to Heating Element or a Burning Wire might cause Such Smell.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 10, 2009 | Fahrenheat Electric Hydronic Baseboard...
We live in a slab home. We have been noticing a order that smells like sewage. It is mainly coming from the floor heating vents in the kitchen and in the back laundry room. Is there a way to find out...
some where under your slab your sewer pipe has broken. most times you must cut away the concrete floor and explore for damaged pipes.
Jul 23, 2009 | Plumbing
I need a wiring diagram for a Fahrenheat electric baseboard heater. model # F2546NWC 1500 watt.
i dont have a diagram but i just did mine,,,its real easy to do...write back if you didnt solve your answer yet...
Dec 26, 2008 | Fahrenheat Electric Convector Baseboard...
My 200 amp Siemens main electric box is heating
This is a dangerous situation! There is a short in the furnace. It is NOT a breaker problem! You need to check the current draw in the furnace circuit, This requires an Amprobe meter. If you don't have one, contact a technician at once! You have a fire hazard!
Ray
Dec 15, 2008 | Fahrenheat LFP6152 Halogen Baseboard...
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Jan 09, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
502 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
