Question about Vacuums
ATTACH UPHOLSTERY ATTACHMENT
I HAVE NEVER USED THE UPHOLSTERY ATTACHEMENT AND CANT FIGURE OUT HOW TO ATTACH IT. INSTRUCTIONS ARE VERYYYYYYYYYY POOR . I REMOVED THE RECOVERY TANK WHICH IT SAID TO DO AND THE SQUARE P IECE WHERE THE ATTACHMENT SHOULD GO. I TRIED TO FIT IT IN BUT AFRAID TO FORCE IT. CAN S OMEONE HELP ME
    Scholar:
  • 190 Answers
What is the Model Number of the Steam Vac?
It should be something like F58XX-XXX
Posted on Oct 03, 2009
No suction for upholstery hose
http://www.hoover.com/pdfs/manuals/F5914900.pdf try priming your hose
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
Follow the instructions on pages 14 and
15 for the appropriate cleaning task.
Godbless
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I need yo find out hoe to use the upholstry attachment. Ilost my
I'm not quite sure where the attachment plugs in but, I did find an owner's manual for this Hoover online.
http://www.hoover.com/pdfs/manuals/F5918900.pdf
I hope that helps. Good luck!
May 25, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Does my kirby come apart to where i can shampoo furniture . can i use kirby on berber carpet. i have the G series
YES there is Kirby upholstery shampoo attachment that comes in a standard set of attachments - HERE is the instructions. Try it on inconspicuous area first just to make sure that this is going to work on your upholstery. But I would just buy a can of upholstery foam. If you can not find it in a store - try automotive store - they definitely have it. Spray can is just much more simple. Still try it somewhere where you would not be afraid to damage the color first.
Using shampoo attachment on berber carpets is not as effective as on the regular carpet. Brush cant get to brush the fiber from all sides. You may have to shampoo berber rugs from several directions to get the better result.
Mar 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do I shampoo my upholstery
Instructions are HERE. Try shampooing on a part of a furniture that is not visible much... sometimes this may not work well.
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby sentra
Remove the bag assembly from the machine.Install the hose to the machine.The upholstery shampooer is simply a trigger assembly with a jar attached.Simply connect the back of the trigger ***'y to the end of the hose.On the attachment case is a cloth covered cap that goes on the other end of the trigger assembly.This is what creates the foam.Fill the jar with shampoo solution.Use the trigger to deposit the foam onto surface.Work the foam into fabric using soft cloth or brush.When it's dry,vacuum the foam and dirt out using the hose attachment on the suction side(front) of the machine
Nov 07, 2008 | Vacuums
I cant find my manuel for my steam cleaner and I want to use the uphostery cleaner dont know how to hook it up can you help me?
In front at the bottom thiers is a peice mine is square pull it up and out, now take the top of the tank lid off. now slide your upholstery attachment in that place where you pulled out the sqare. the open end facing up, now put the tank lid back on every thing should work .your welcome ttsgma01
Sep 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning uphoustry
Furniture cleaning isn't a science: try out a few techniques before choosing the one that is right for your belongings. This step-by-step guide explains how to clean a sofa:
  1. Before using any upholstery cleaning products, vacuum the sofa or chair first to remove as much surface dirt and dust as possible. Be sure to use the correct attachments to avoid damage to the material - a soft brush attachment is ideal.
  1. Spot Clean. Using baby wipes or vinegar poured onto a strong microfiber cloth, apply to any obvious stains, wiping gently as you go. Remember to test the upholstery cleaning products on an inconspicuous area first.
  1. Overall Clean. Using soapy water and a microfibre cloth, gently wipe your sofa with the solution, allowing it to soak into the fabric and tackle the dirt beneath the surface. You only want to use a very small amount of water - don't saturate the material.
  1. Dry. Some people use a hairdryer to quickly dry a sofa, but allowing it to dry naturally is always the better option, if you have the time. To speed things up, open windows and allow the breeze to help with the drying process.
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Apr 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning uphoustry
I CANT FIRGUE OUT HOW TO PUT IT TOGETHER
Mar 05, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Using upholstery attachment on the hoover spin scrup heated cleaner
I had the same problem. Instead of wasting time/energy I could use cleaning the furniture, I decide to look online for a manual instead. I hope this helps. It helped me!! http://hoover.com/pdfs/manuals/F5914900.pdf Good Luck !!
Sep 08, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
211 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
