Question about Whirlpool LER3624JQ Electric Dryer
How do i remove the front of the dryer???door opens sideways not up and down
  • 193 Answers
After opening the door,you should see four phillips head screw going vertically up into top.Remove screw and lift upward
Posted on Sep 29, 2009
Remove front panel and door on maytag electric dryer atlantis
Simple, 4 screws total. open door, remove one screw from each of the door hinge plates that are against the front panel, remove two screws directly across the door opening (other side of dryer), door can be lifted slightly and pulled out of slots, and front panel can be unhooked from retaining clips by a little wiggling at the top sides, swing it down toward the floor and lift it from bottom retaining hooks.
Apr 14, 2013 | Maytag Atlantis MDG8400AW Gas Dryer
HOW DO I REMOVE THE BACK OF MY GE DBXR453GAWW TO CHANGE BELT
you don't get at it this way,you remove top 4 screws on control panel,then slide control panel sideways to remove,then open door and at top of door land 2 screws hold top down,remove these 2 screws and remove top,then inside the front panel on either side there are 2 screws holding front panel remove these then undo door switch wires and set front panel aside,then remove belt and replace on drum
Dec 24, 2012 | Dryers
How do I Disassemble a GE Profile Dryer to replace Drum Bearings? Model: DPSQ475ETOWW?
remove 4 torx screws from the top of control panel,then slide control panel sideways till you can lift it up off the top cover,then open the dryer door on the upper door land area there are 2 screws going up into the top cover remove them then you can remove the top cover,then on each side at the top there is a screw holding the front panel in place,remove these then you can remove door switch wires from the door switch and lift up on this panel to remove it off the gussets on the bottom of the door,then you can install the top door bearing and 4 drum slides
Nov 29, 2012 | Dryers
How do I get the top off
The front panel needs to be removed first before the top panel can be lifted. This is due to the top panel hold down brackets hidden behind the front panel posts. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order. Click on the link below for more detailed disassembly procedure.
Removing the Front and Top Panels of Maytag Sloped-Front Dryers
Mar 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
How to open the top of a Maytag MDE9206 dryer? Makes loud noises want to investigate
The top cover is attached to two hold down brackets, one on each side, and it can only released once the front panel is removed. Disconnect power then open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Feb 10, 2011 | Dryers
Remove top to get at drum
The front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Oct 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I open the front ofthe dryer?
Open the door and remove the screws holding the top down to the front. Then remove the top and remove the front. I have repair photos:HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 11, 2010 | Dryers
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
How do I open the front of my whirlpool lgb6000 dryer
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right.
Oct 27, 2009 | Whirlpool Dryers
Whirlpool LER3624JQ Electric Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
