Question about Boating
Spark plug gap 150 hp Yamaha outboard
Need spark plug gap for 2003 Yamaha outboard 150 hp motor.
  • Anonymous Mar 29, 2014
    Yamaha 150 HP outboard
  • Mike Mitchell
    Mike Mitchell Sep 12, 2014
    I have 1994 yamaha 200 H.P Jet, I run NGK BR9HS and it calls for gap at .058 - .063...
  • 86 Answers
The correct gap is .035
Posted on Oct 16, 2009
What is the yamaha spark gap for jet ski engines 1990 year
0.024
http://www.globaldenso.com/cgi-bin/global/plug/usa/pw/pw-plug.cgi?filename=pw-14.txt
Sep 01, 2014 | Clymer Yahama 2-250 HP Two-Stroke Outboard...
Spark plug gap 1999 yamaha 30 hp 2 stroke
if its got a 10 after the letters and numbers on the plug then its 1mil !
Aug 07, 2014 | Ngk Spark Plugs For Outboard Engines Plug,...
Yamaha 2.5 hp outboard motor spark plug gap
I Would Recommend a 0.8 Gap
Mar 10, 2013 | Boating
Yamaha 200hp 2001 manual
  1. Fuel
    • A common problem with an easy solution, Yamaha boat engine trouble could arise due to inadequate levels of fuel or engine oil. All Yamaha outboards take unleaded gasoline as a main fuel source with a pump octane rating of 86 or higher. The type of engine oil varies according to motor size and can be found in the "Specifications" section of a particular outboard's owner's manual (See Resources).
    Electrical
    • Problems with the electrical system can also prevent a Yamaha outboard's engine from working correctly. Troubleshoot the electrical system, first removing the main fuse that's located underneath the electrical panel on any electric-starting outboard. If the connection at the center of the fuse is broken, it must be replaced by a fuse of the same amperage. The battery should also be removed, cleaned and fully charged when troubleshooting the electrical system.
    Spark Plugs
    • Owners should also remove and inspect the spark plugs during the troubleshooting process. If the insulator tip of any plug is burned, that spark plug should be replaced. The number and type of spark plug depends on the specific outboard. Additionally, owners should ensure that each spark plug gap is set to the width stipulated in the owner's manual (see Resources).
Jan 20, 2013 | Motorcycles
Spark plug gap 03 yz450f yamaha ?
Hi, Frank for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2007 yz450f spark plug gap YZ 400 426 450
Spark plug Gap
YAMAHA YZ450F Owner Service Manual
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-11_784.pdf
Mar 20, 2012 | 2003 Yamaha YZ 450 F
Spark plug gap for 2004 150 hp yamaha outboard
2004 mercury 150hp,v6 2stroke,spark plug gap
Jan 18, 2012 | Boating
Yamaha outboard 150 4 stroke bad vibration at 700 to 1200 rpm run great in nuetral and over 1200 rpm what could it be
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 03, 2009 | Boating
Not getting gas to motor on 150 efi,engine will try to turn over
need year and make? Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the year and make I'm giving you a average numbers. Look at your Clymer manual for specific specs. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten .Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine cowl clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the make so I guessing what fuel injected system. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works. without the test information I would guess the electric fuel pump. but test everything first because a mercury efi fuel pump will set you back 600.00
Sep 15, 2009 | Nitro Boating
Boating Logo
1,384 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
