Question about NetGear XE102 Powerline Ethernet Adapter (XE102US) (D85639) Bridge
My download speed has been reduced from 20 Mbits to 2 Mbits after having plugged in a set of XE102. Why? Can I do something ? Regards Mogens Villy Møller Copenhagen Denmark
  • 3,287 Answers
The top speed between the devices is 14 Mb/s, so they will never attain the 20Mb/s speed you had with you router / modem.
Netgear offers this FAQ for Powerline devices:
Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
  • Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or uninterruptable power supplies.
  • Passwords. Powerline products have both a network password, and a device password. A particular device's password, which is not changable, is printed on the Powerline product label. Once you have collected all your Powerline device passwords, use the encryption dialog box, as described on pages 9 and 12 of the XE102 User's Guide, to change the network password. (Without password protection, it is possible, although unlikely, for someone very nearby to access your network.)
  • If you changed the default network password, make sure that all the Powerline products use the same network password.
  • If you've moved a Powerline unit, or disconnected the cables, your other network devices may need about 5 minutes to refresh their information about the Powerline's current status.
  • If you have earlier Powerline products, switch to the encryption used by later products. (Early versions of XA601 and XE602 are known to have compatibility problems with newer models.)
  • To test whether a house's electrical wiring is contributing to Powerline problems, plug units in the same room. Examples of potential problems are:
    • Old fuse boxes.
    • Old wiring that does not meet modern wiring building codes.
  • Swap devices to isolate the problem to a particular Powerline unit.
  • Reset the Powerline adapters to the default settings using the utility.
  • Use all the same Powerline models for best connectivity. Also, software for one model may not work for another model. In particular, remote and advanced features may not work between Powerline manufacturers.
  • Powerline is not directed at businesses, however it may work in a business environment, anyhow. See Assessing Powerline for Business Environments. In some cases noise can be limited by placing line conditioners or surge protectors between the source of the noise, and the Powerline units. (Not between the units.) Consult a professional electrician to evaluate your electricity's noise and to suggest remedies.
Posted on Sep 29, 2009
Testimonial: "Yes, thank you.I have got some options to try out, especially the condition of the electrical wiring, and the need for a protective password. Mogens "
I have a 2wire modem and in the DSL Connection Details, the Downstream Rate is 6016 kbps but when i do a spead test on the internet , I only have 2.5 or so kbs? I would like to know if there is a setting...
Are you sure that the speed-test is reporting 2.5 Kbps? Could it be 2.5 Mbits/second?
Have you closed all other network-using applications (Limewire? Windows Update? Adobe Updater?)
Note that some DSL-providers have different levels of speed, for different monthly payments,
e.g., $20/month for 512Kbit/second, $40/month for 1.5Mbit/second, and $60/month for 2.5Mbit/second. Pay your ISP more per month to higher higher speeds.
Dec 07, 2010 | Computers & Internet
Hi I have a belkin F5D8233-4v3 router but the speed isn't what it should be. I have a 100/10 Mbit connection but when I have my computer connected through the router with a cable all the speed tests I try...
The speed of the wireless connection can be affected by -
1. The signal strength
2. Clashes with other wireless routers in your area broadcasting on the same channel
3. Electrical interference with the wireless signal
4. WEP & WPA Encryption of the wireless signal to prevent unauthorized access does slow the data transfer a bit.
That is why you are getting better performance using the LAN cable.
Jun 09, 2010 | Computers & Internet
I have MacBook and it is not recognizing the ethernet connection
1. First check the light status of the XE102.
2. Then hard reset the Xe102
3. As this is a plug n play device all the lights should come on.
4. In case if the lights wont come on.
5. Check the powerline ..
6. And if that will not work , get a new adapter or replace the existing one from netgear ( 1-888-638-4327 )
Jan 26, 2010 | NetGear Powerline XE102 Ethernet Bridge...
USB taking too long to transfer vista
Note that USB ports (in your computer) and USB devices can either be "USB 1" or "USB 2" speeds.
While "USB 2" to "USB 2" connections are up to 480 Mbits/second,
any "USB 1" to "USB 2", or "USB 1" to "USB 1", connections,
will max-out at only 11 Mbits/second.
So, check that you have a "USB 2" device.
then check that you are connecting to a "USB 2" port on your computer.
Give more details about your computer, and your USB device.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
Does a compaq presario 5000 support flash drives
Yes, it does.
The Compac Presario 5000 series have between 2 and 4 USB 1.1 Ports.
Note here that the ports are version 1.1, which is considerably slower that version 2.0.
USB 1.1: 12 MBits/second
USB 2.0: 480 MBits/second
Aside form the speed, they are both compatible with your computer.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 26, 2009 | Compaq Presario 5000 PC Desktop
No lights come on when I switch on my XE102.
Though, it is not repairable, yuu may contact NETGEAR to get the unit replaced if it is still under warranty. Contact them http://my.netgear.com
Regards
Anand
Aug 08, 2009 | NetGear XE102 Powerline Ethernet Adapter...
Netgear wall plug XE102 stops working when downloading
It seems to be an issue either with the powerline adapters or the electric line. Swap the devices and check if it helps. Also, disable encryption utility if being used
Try connectig both teh devices in the same room and check the download speed
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 24, 2009 | NetGear Powerline XE102 Ethernet Bridge...
Can't get network connection using XE 102 and WGX 102. Have Mac computer and a linksys router. In room with the router, I pick up the linksys network on my MacBookPro laptop. Installed (hardwire) XE 102...
If you are able to pick signals on the laptop, i am sure that your router & mac book are good.
there are only two possibilities to work on ;
1.) look for any interference between the router & computer in the other room like ( refrigerators, television, Music systems, AC, Thermostats)... by pass 'em if required.
2.) The installation of the reciver on the Mac book might require a range setting.
Fame !
Jul 04, 2009 | NetGear XE102 (XE102US) Bridge
The middle light on my netgear ethernet bridge xe102 wont stay on
-- Xe102 device is simply a plug n play device
-- so if the connection light shut off after some time
-- first hard resett the powerline adapter
-- and after that get the powerline checked
-- If that doesnt work there is no specific configuration
get the adapter replaced ..
Jul 01, 2009 | Powerline Netgear XE102 Ethernet Bridge...
Trouble installing XE102 Powerline
there wasn't actually any problem with the device. For these bridges to work, you need to be on the same phase of the wiring. If the devices are on different phases then they can't communicate. But I still couldn't get the encryption to work. Netgear support doesn't seemed to be bothered with that...they told me to ignore it.
Dec 16, 2008 | NetGear XE102 Powerline Ethernet Adapter...
NetGear XE102 Powerline Ethernet Adapter (XE102US) (D85639) Bridge Logo
294 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
