Question about OKI C5200n Laser Printer
542: C Toner Sensor Error-I cleaned inside and cartridege sensors-still has error?
4 Suggested Answers
  • 35 Answers
SOURCE: The printer message window says: Check Toner
check ur cartridge.. it might wrong place
Posted on Oct 24, 2009
  • 46 Answers
SOURCE: message on window: check toner cartridge 542: C
try a different toner first .... doesn't have to be a full one ... just a different toner box. had the same on a machine and it was only a bad toner cartridge. so the easiest thing to do is swap drum units with toner installed ...
if it turns out to be the cartridge you can have a look at the right side ... there is a hole in it and a white plunger moving there and gives the machine the current toner amount in the cart.
SOURCE: Hi I have a 542 toner sensor error
you need to clean toner sensor inside the cover
please look user guide on your printer manual
Posted on Jan 06, 2010
How do I break the error code E000024-0001
E024-0001 Error Code:
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
However, re-attachment of the sensor also solves the symptom.
When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
One problem found has been the toner sensor scraper blade in the developer not making contact with the surface of the toner sensor.
To check the toner sensor scraper blade first set up a work area. Lay out several sheets of 11 x17 paper on the work surface. Disassembling the developer is a messy job. Remove the upper cover of the developer and then rotate the developer in a counter clock wise direction. Basically the cylinder should rotate so the toner is scraped off of the cylinder by the developer blade.
If it is rotated in the wrong direction a large amount of toner will adhere to the developer cylinder and makes a mess.
The toner sensor is located on the on the outside of the developer and part of it goes through the wall of the developer unit.
Next look at the inside surface of the developer where the toner sensor is mounted while rotating the developer cylinder in the correct direction. There is a mylar scraper sheet that needs to touch the inside surface of the developer wall. In the image below the inside surface of the developer wall is being touched by the mylar scraper blade. If the blade is damaged or broken off the toner will not be cleaned off of the sensor and give the error code E024. If the blade is the problem the developer will need to be replaced.
The part number for the developer is FM2-0287-010.
Jun 19, 2013 | Office Equipment & Supplies
Phaser 6128 mfp error sensor ctd
Open up the side panel that houses the toner cartridges. One by one pull out the toner cartridges, with a clean dry cloth clean off the injection port(?) on the cartridge and the injection port on the printer(this will be just inside the where the cartridge locks in. Sometimes these ports get clogged with toner and need a good cleaning, causing a CTD sensor error. Our 6128mfp does this error all the time and we have not had to purchase the new parts to fix the error.
Aug 07, 2012 | Xerox Phaser 6128MFP AllInOne Laser...
Code error E000024-0001 in canon model ir-2830.pls tell how to rectify the problem
error from developing unit.try to blow all the toner and reinstall new toner .clean the p/j linking dp unit .check for toner intake .if the toner is low and toner motor does not operate or there is toner dump in dispensing
Sep 07, 2010 | Office Equipment & Supplies
I have toner sensor error , the screen reads check toner cartridge 541:MToner Sensor Error
In most cases you need to use a can of air and blow out all around your toner and drum area. Then used it inside the printer to clean out the toner inside of the machine. If this doesnt work take out all 4 anc clean everything very well.
Jan 21, 2010 | OKI C5500n Printer
Jan 06, 2010 | OKI C5500n Printer
Message on window: check toner cartridge 542: C toner sensor error
Oct 24, 2009 | OKI C5500n Printer
I have a C3530 MFP and it won't print because it says check toner cartridge black. Toner Sensor Error
Hi
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | OKI C3530N Color MFP Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
OKI C5200n Laser Printer Logo
684 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
