Not abe to boot up
I have a pavilion 1310n upon starting i get the message windows cannot start following file missing windows\systems32\config system. i have no orginal recovery disk. i try the system recovery f10 it says it download files sucessful but get the same message error when rebooting
    Problem Solver:
  • 13 Answers
YOUR WINDOWS FILE IS CORRUPT AND YOUR RECOVERY CD AND BACKUP WHICH IN HIDDEN IN THE SYSTEM IS ALSO CORRUPT . YOU HAVE TO INSTALL WINDOWS AGAIN IF YOU KNOW OTHER WISE CONTACT SERVICE CENTER FOR YOU PC.
Posted on Sep 29, 2009
Windows\systems32\config\system file is missing or corrupt
You can order a new set of disks from the manufacturer or pull out the had drive and plug it into another PC or buy an external hard drive dock . Newegg has them for around $20
Mar 09, 2014 | Insignia Computers & Internet
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
When I start up my Dell inspiron 1300 a message comes up which says "windows could not start because the following file is missing or corrupt: \windows\system32\config\system Please help wat do I...
if you have the laptop recovery disc, then using the disc reinstall the windows. If you do not have then use a boot-able CD and reinstall/repair windows. it seems some system file missing.
Aug 31, 2010 | Dell Inspiron 1300 Notebook
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
I have another computer that won't start. the screen says - missing \windows\systems32\config\system use original setup cd rom select r to start repair I tried but it doesn't work
you need bootable windows disk or recovery disk.
Then set first boot device as your cd or dvd rom.
when you power up the computer press F1 or F2 or "del" key to enter in bios then go to boot option then save settings.
thenh put cd in cd /dvd rom then it boot with disk.
Then it load some file wait for 5-7 minutes then it gives screen then press enter.
then followe the instuction.
Aug 08, 2009 | Computers & Internet
Missing or corrupt
HI,
You canrecovery the MIssing file, by installing the OS
Don't go for installation ,give Repair the option
when you boot up the Lpatop,
press either F2 or Del, this will get you into the cmos settings, navigate to advanced cmos settings and normally at the top line is the boot sequence which will say HDD, press either up/down keys or + - keys to change to cdrom as first boot device, save settings and exit.
Insert you cd rom before the system boots into windows and the option prompting you to press enter to boot from cd will appear for 30seconds.
ok---enter---repair-- in this option it will recover the missing files.
May 19, 2008 | Toshiba Satellite M55-S3512 Notebook
Acer travelmate 2420 laptop
You don't need the original setup cd as long as you have the windows cd you can boot up the pc using that cd and just repair the windows or install it over cause its only a file messed up. Get back to me
Apr 17, 2008 | Acer TravelMate 2300 Notebook
It won't boot
Hello maybelle,
Your system is corrupted, files needed to boot up windows was corrupt or it was deleted accidentally, the only solution that can correct the problem is provide installation disc(windows installer) and insert it to the CD ROM and boot your system to CD DOM and follow the the on screen instruction.
(note: installation of Operating system can lost your important files, back up the files)
installation of OS refer to this info: http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
please do not rate me if the solution not solve the problem.
if need more info, please notify me, i will give you more information.
best regards.
Apr 09, 2008 | Toshiba Satellite M35X-S161 Notebook
Having problems with my compaq Persario 2500
this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
