Question about Nokia 6680 Cellular Phone
Mmc my phone does not show memory card,but i have another mmc card hich shows same result,please tell me a solution of my phone before this event four day's ago it shows a message'removeing memory card close all applications' but iam not open the phones back or removig memory card. hi there! i had the same problem with this nokia 3230... when my battery got empty, i took out my memory card. but when i put it back in the memory card slot and open my phone... all my applications are gone... i did go to check my memory card but my phone says no memory card inserted even if it has a memory card in it... i just thought that it was a memory card problem, but wen i inserted my memory card on my freends cellphone, their phone reads my memory card. and vice versa, i borrowed a memory card on my 2 friends and inserted it in my phone, i had the same result (no memory card inserted)... can u help me with this??? thnx!
  • khazy04 Dec 22, 2007
    great! tnx! my phone is ok now! :-)
  • 1,944 Answers
Chances are that the software on your phone has become corrupted. I would advise doing a master reset on the phone and see if the problem persists. If that doesn't help...probably the card slot has malfunctioned. Most probably a reset will slve the problem. Good luck!
Posted on Dec 19, 2007
Hai, n95 mobile any memory card insert showing memory card currupted please help me.
Here is my post TIPS on how to recover an accidental MMC corrupted.
just follow the guidelines and for sure your MMC content will be fully recovered.
good luck....
Jun 15, 2011 | Nokia N95 Cellular Phone
I hv forgoten my NOKIA 5130 music express memory card passward. Even memory card is not showing in PC.And from mobile when i clik memory it wants password........ please, tell me the...
The easiest way is to format your MMC from your mobile phone,PC can't see it because is password protected.If you don't wanna loose any information you can take a look here :
Apr 20, 2011 | Nokia 5310 Cellular Phone
I have 8 gb mmc and im unable to format it on my pc as it shows no card and i cant even format is through my phone it shows mmc corrupted
Hi there and welcome to fixya,
That's a common problem with MMC's... here something that might help:
Use a pencil and erase the contacts of the MMc card, this will reveal the shine on the contacts. Try replugging it again.
I sincerely hope this would work out in your condition,
Dec 27, 2010 | SanDisk 2GB microSD Memory Card
On my Nokia N70, my phone memory card is not accsesible . Even it shows " No Memory Card inserted " on my Mobile after inserting it into phone and when i connect it to computer it does not shows memory...
first connect your memory card to a card reader and check wehther it is recognising...if no,sorry to tell you this, your memory card is currupted. formating is the only one way to get bak your memory card...hope this will helps you...thank you...
Oct 15, 2009 | Nokia N70 Cellular Phone
Not able to reformat 512MB MMC card of NOKIA N72
make sure you formatted it to fat32,then put back in the phone(without the music yet)back up phone to the mmc card.. when you have done that find the music folder on the mmc card and put your songs in there.
Jun 03, 2009 | Nokia N70 Cellular Phone
Nokia 3500 mmc password rest
Dear Kaushik,
Kindly try the following as a fix for your problem:
Attach it to a memory card reader linked to your PC, then search the root files and look for a file called mmc. when you find the file it will have a symbols and lines, you need to find any sequence of letters or numbers. Copy those and paste them unto your phone as a password.
I hope this solves your problem.
Feb 27, 2009 | Nokia IP 350 Firewall
3650 phone start up failed pls help me
u have to reset or mobile do that follow this
1. Removed your MMC card first.
2. Make sure you have at least 3/4 charge of battery before performing the
" Safe Mode, and follow-by phone reset *#7370# ". Or maybe you can have the
charger on and plugged into the phone to act as a full power source.
3. Press and hold the ABC key and then press the power button.
Remember not to release the ABC key till you seen the
"Safe Mode" standby screen.
(Fyi, there's no special indicator that telling yo're on a "Safe Mode"
standby screen.)
4. Once in the "Safe Mode" stanby screen press *#7370# to carry-out "Phone Reset"
5. Once "Phone Reset" task completed and back to normal standby screen again,
switch off your phone and re-insert your MMCmag-glass_10x10.gif card.
If any error showing on the phone boot-up, please have the memory card formatted and by next phone
start-up you will not have the error msg again.
If you some important data or programs files on your MMC card, please use
a card reader to have them copied onto a pc before performing memory card
Dec 04, 2008 | Nokia 3650
Showing memory full
the bestb thing to do is formatt your unit, and the MMC'
after you have formatted the MMC in you phone,
set you massage in setting>other>select MEMORY in USE' put in MMC in use. so all uyour massage will directly save in MMC even it has High mb/kbs...
Mar 11, 2008 | Nokia N70 Cellular Phone
try by restoring handset once a time or else memory card is corrupted..change it....
Oct 18, 2007 | Nokia N70 Cellular Phone
aarey yaar your cell is attackd by a trojan plz install a gud antivirus.if u r nt gettng it then mail me at
May 20, 2007 | Nokia 3230
Nokia 6680 Cellular Phone Logo
140 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
