Question about HP PSC 1510 All-In-One InkJet Printer
Printer misfeeds my printer when powered up will partially feed a sheet of paper and stop. the check paper light comes on. I push the cancel button and the paper continues out and another feeds partially in. I've also pulled the paper out when the paper partially feeds and then push the button, paper continues thru the printer and the check paper comes back on. I place paper back in tray and paper feeds partially.
  • Anonymous Mar 18, 2014
    Will not pull paper into printer
  • Anonymous Mar 26, 2014
    paper stalled light and printer waiting come on. When I push the ok button paper comes out and the two errors come back
    Scholar:
  • 54 Answers
1. Unplug the printer power cord and remove the back door.
2. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around.
3. Allow the rollers to dry completely, then close the rear door.
4. Open the print carriage access door.
5. Use a clean, dry cotton cloth to wipe the carriage rod. Move the carriage as needed to clean the full length of the rod. Do not lubricate the rod.
6. Close the printer, plug the power cord in, and turn on the printer power.
Ensure that you select appropriate paper type and size before printing.
Thank you
Posted on Dec 22, 2007
Misfeed- cleared, but still says misfeed is there
Hi
1st when using transparency paper U must set up the printer propreties to paper kind U use.
for now do the sim. 30 -1 to see hows sensor is detected bi touche
Jun 16, 2014 | Sharp MX-2700N Color Copier
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Started out with paper, would start to load paper them as soon as paper stared in would stop. After several tries it would work. Then it stoped taking paper at all. Each time you try to print it stops and...
    First I would remove the paper tray and check the rollers and print path for any scraps of paper that may be tripping up a sensor. If all seems well, ...
    Try this next: It will reset the printer's configuration info.
    To factory reset your Dell 1700 series printer follow these steps.
    1. Turn off your printer
    2. Open the front cover (push the button on the left side)
    3. Hold down the "Continue" and "Cancel" buttons and turn the power back on.
    4. When the "Error LED" light on the control panel is solid, close the cover and release the "Continue" and "Cancel" buttons.
    Tip: To print a configuration sheet push the "Continue" button twice. This will give your printers IP Address.
    Dec 31, 2010 | Dell 1700n Laser Printer
    I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
    The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
    http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
    When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
    Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
    If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
    Trust this is helpful. Please vote. :)
    Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
    My Ip90 won't feed paper when I try to print a job.
    If the paper does not feed properly it could be due to the follwong causes.
    Cause 1 : Inappropriate paper type used
    Action : * Check to see if the paper you are printing on is too thick or curled.
    * Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
    Cause 2 : Paper Feed Roller is dirty.
    Action : Follow the steps described below to clean the Paper Feed Rollers.
    If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
    1) Ensure that the printer is turned on and there is no paper loaded in the printer.
    2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
    The paper roller rotates as it cleans.
    3) Repeat this cleaning operation one more time.
    4) Load a sheet of plain paper in the printer.
    5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
    Cause 3 : Paper jams.
    Action : Remove the paper according to the following procedure.
    1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
    * If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
    Caution: Be careful not to touch any components inside the printer.
    * If you cannot pull the paper out, turn the printer off and turn it on again.
    The paper will be ejected automatically.
    2) Reload the paper into the printer and press the RESUME/ CANCEL button.
    If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
    Hope this helps.
    Please rate my response.
    Thanks
    Have a good day.
    Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
    What does the button mean :/\/ that is above the! mean?
    The button above the ! is paper jam indicator. Does the light appear immediately after powering on the printer. If yes check paper sensors. If it only comes on after trying to print, it could be a paper misfeed.. Check the feed rollers.. you can turn them inside out for better grip on the paper as a diagnostic method.
    May 15, 2009 | IBM Infoprint 1412 Laser Printer
    The machine gives a false error message.''misfeed A :internal path
    Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
    Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
    Will not automatically feed
    I had to fix similar if not the same problem in the office today. After you load paper, the paper holder steel plank should pop up. In my case it didn't, the result was what you have described. To solve, before you close (push in) paper tray, on the lower right side of the paper tray there is a little plastic button, push it up from the buttom. This will pop up the steel plank on which paper rests, then close tray.
    It worked for me...
    Aug 14, 2008 | Sharp AL 1631 Copier
    Misfeed indicator
    It could be comming from the paper feed mechanism above the paper tray. Make sure its installed properly. It could be as simple as cleaning the feed tires.
    Jul 12, 2008 | Sharp AL 800 Copier
    Check paper light blinking and "E" code
    trying to print the las job you had.
    Try hiiting the cancel button when you turn it on
    Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
    HP PSC 1510 All-In-One InkJet Printer Logo
    147 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
