Question about Hotpoint VBSR3100D Top Load Washer
Panty hose stuck under agitator want to take off agitator to remove
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
Washing machine not draining
Spin cycle is probably messed up
Mar 06, 2013 | Washing Machines
2008 model number not found on selection list, model #nfw7200tw washer did not spin and drain out dirty water and complete rinse and spin dry cycle, tried to reset by manual instructions and it would...
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. If this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift it up hard... see the picture. Hope this helps...please post back for further assistance.
Daniel
Feb 05, 2011 | Amana Washing Machines
Water is draining very slowly out of the washer and if it takes to long it gives a code of DR
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. I f this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift up hard...picture. You can also clean the drain hose as that might be clogged if the agitator is fine. Hope this helps...please post back for further assistance.
Daniel
Jan 10, 2011 | GE Spacemaker WSLP1100D Top Load Washer
How do i remove agitator to pull out panty hose stuck under it?
Look inside the agitator where you put the soap. At the bottom there is a flat loooking piece that screws out by hand if you have the type with a stand agitator. If it is the new style, one that is virtuall flat, pop off little cap with a screwdriver. Look for little slots under the cap. Then remove bolt and pull up on the agitator plate.
Dec 02, 2010 | Fisher and Paykel Washing Machines
Clothing stuck under agitator
The agitator pops off. You will need to use a flat head screw driver or something short enough to get in the tub and under the agitator and it will pop off. They are on there pretty good so it will take some work
Jun 01, 2009 | Fisher and Paykel WL26CW2 Top Load Washer
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Washing Machine Repair
you will have to remove the agitator
There is no other way. Not to hard to remove it though.
good luck
Jun 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint VBSR3100D Top Load Washer Logo
116 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
