Question about Canon i850 InkJet Photo Printer
Every 4th or 5th line does not print
Today, my four-year old Canon I850 stopped printing every fourth or fifth line of text  Paper tray is full.  Cartridges are full.  No settings have been changed.  Any suggestions.  Thanks.  Lindagolfer.
  • 1 more comment
  • Schirm Feb 28, 2008
    I have the same problem, every 4th line does not print. I ran the recommended maintenance sequence (cleaning, deep cleaning, print head alignment, nozzle check), no luck! Any other ideas?
  • oracle99 Nov 10, 2008
    I have the same problem. I did all of the maintenance and even reinstalled the drivers and still not printing every 4-5 line.
  • sjhovey Jan 31, 2009
    I have done everything suggested in Solution No. 1. No change.
Try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Posted on Feb 12, 2008
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
My canon i850 is blinking 3 orange lights at me and refusing to print. any ideas. tried turning on and off. removing print driver and re-installing thanks!
3 blinks is a line feed error, something stopping the platen roller from turning, look inside where the paper goes and see if something fell in like an ink pen, paper clip, just something that doesn't belong. The platen roller is the gray roller behind the carriage and sometimes you can see thru under the white plastic guides something jammed.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
I have problems aligning printer heads on my Canon i850. I have clean the printer heads, replaced cartdridges, re-aligned them, but I still get lines through the printed material (phots mostly). No...
Please try to uninstall and reinstall your printer.
Clean your printer heads.
Perform a hard reset to your printer.
Print a test page.
Try using a different bond paper.
Make sure you are using original canon cartridge
If still you get an error. Replace your printer heads.
Aug 30, 2009 | Canon i850 InkJet Photo Printer
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
Size of page printed small
Check your default paper size on both the document program you are using and the printer. You could have it set for 5X7 and that's what it will figure for, even with 8 1/2X11 paper.
Jan 30, 2009 | Canon i850 InkJet Photo Printer
Printer does not print
Change the paper type to anything other than plain paper. It works but I do not know why.
Sep 10, 2008 | Canon i850 InkJet Photo Printer
Paper jam
can u see any part of paper anywhere in paper ,usually it gets stucked on the back side in the fuser assy ,remember dont try to remove any paper with any metalic tool even if u find any peice of paper
Jan 23, 2008 | Samsung ML 2010 Laser Printer
Printer will not print black ink
Chewbacca08's solution gave me an idea. I set the print setting to photos paper (even though I was trying to print on plain paper) and IT WORKED. It's worth a shot before you trash a perfectly good printer.
Jun 25, 2007 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
161 people viewed this question
old marine
old marine
