Question about SanDisk Sansa View 8GB MP3 Player - Black
It doesnt turn on just the blue light on the wheel
It just turns on the wheel light and when i connected to the usb and computer it also does that.it just stay blank and doesnt show anything
    President:
  • 803 Answers
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Posted on Oct 01, 2009
Why wont my unit charge?
If it is steady blue then it is ready to be found by your phone. If you see the headset in your phone remove the pairing and repair again. You should hold the multifunction button after turning on until it goes steady blue if you aren't getting a steady blue light in order to pair it.
Jun 26, 2014 | Motorola Mobility Bluetooth Hands Free...
I have a swagger sakar mp3 music player - when you plug them into your computer with the USB wire, it is supposed to charge up. Does it have to be turned on or off or does it matter?
Bought my wife one at JC Pennys, Computer doesn't recognize it and no red light ever showed up however a blue one does also the website listed in the paperwork www.sakar.com doesnt even list the swagger mp3 player
Nov 08, 2010 | Sakar MP3 Player
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
Computer isnt running
If that is the case your system need to check the battery for fault and does it happen with the power source too i fthe same problem check your processor fan if its bad when you on the system and is not blowing that might have cause the processor itself to get bad you will have to change this ones and then your system will be ok right rate this solution.
Nov 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Fell and now cannot access the drive
there can be 2 problems:
1) VIRUS INFECTED
2) DLL file is infected
May 17, 2008 | Fantom Drives 120 GB Hard Drive
Light doesn't turn blue at all
Plug it into another computer if possible, clear ALL files on it.
You must of been sending something to it when you flicked the switch, they would normally go off straight away.
(Backup on the other computer first)
If this does not work then you may want to see if you can see a usb stick in your USB ports. If you can it's a fault with the harddrive, nothing else you can do.
Mar 31, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
MP3 Won'T TurN on PLZ HELP!
When you dropped it, the batter became loose from the contacts inside, therefore it doesnt charge, but lights up when you connect it to the computer. Remove the 4 screws on the back, then take out the battery and then press it in firmly. Charge the device for about 2 hours. Please add to the question for additional assistance. Best of Luck.
Oct 03, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa View 8GB MP3 Player - Black Logo
197 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
