Broken usb flash drive
Hi, my daughter's usb flash drive has broken and all her year 12/vce notes are on it. It has separated - the silver section that plugs into the usb port in the laptop broke off the drive. Please can the data be recovered?\r\nthanks Mary
    Guru:
  • 352 Answers
Check to see if there is a data recovery company in your area. some computer repair shops will do it, but it can be costly and time consuming. had a friend who kicked his flash drive out from a computer sitting on the floor. a local company quoted about 120 bucks to recover the data. good luck.
Posted on Oct 15, 2009
  • 2,229 Answers
The data is not destroyed, but it will be tricky to fix. I would suggest you find a local computer tech who is really good soldering tiny stuff. Or go to a Radio/TV repair shop. I think it will be possible to re-connect the wires and make it work.
Posted on Sep 29, 2009
My USB Toshiba 8GB show only 4MB
hi,
some part of your flash drive sector might corrupt or bad.
the windows operating system automatically repair the flash drive or card , so that's why the unreadable sector or bad sector of the drive will be defrag separately from the operational sector, to be able to secure your files.
Apr 22, 2015 | Toshiba 8 GB microSD - 1 Card - Class 4
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
How to install flash drive in windows vista
Just plug it in and vista will automatically install the drivers for it..
Jun 30, 2012 | Lexar 16GB JumpDrive TwistTurn - USB Flash...
My computer will not pick up my drive when i put it in
The windows disk management utility will help solve this issue most of the time. Use the directions below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 20, 2011 | Computers & Internet
Where is sandisk repair centre in banglore? my 8 gb pen drive is not able to access by the computer and it is not getting formated
You can work at formatting you cruzer using windows disk management utility. The instructions are listed below. This may help you avoid going to the repair center. If your computer does not see the flash drive and you see no activity, the cruzer may failed. These 2 gb flash drives are really cheaper to replace than to repair in todays market. Also here is a link to Scandisk support showing directions and images refering the use of disk management.
http://kb.sandisk.com/app/answers/detail/a_id/10/sno/0
Here are the directions:
- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
If you found this information helpful, please remember to leave positive feedback.
Thank You,
Brian
Feb 11, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My sea gate external hard drive can not open and my computer can not read it
Using the windows disk management utility. This will tell you if the hard drive is connecting to the computer or if it is a hardware problem. Sometimes, power cycling the external and restarting the computer will help. Below are the directions for using this utility:
A menu will open
Chose "Manage"
Please remember to post positive feedback if this solution was helpful. If not, please let me know and I will assist your further.
Thank You,
Brian
Jan 25, 2011 | Seagate FreeAgent Go 500 GB USB Hard Drive
Windows: USB Dongle shows up in Device Manager as Disk Drives: KVM vmDisk USB Device, and DVD/CD-ROM Drives: KVM vmDisk USB Device. Steals drive letters I need. How to get around this? have uninstalled...
Hi Bruce:
Sorry to hear that you are having problems. If you still want to use the device, you can assign drive letters to you other devices that do not disrupt the use of you KVM switch. Using device manager, you can change drive letters on all drives except your hard drive, usually drive 0.
A menu will open
Chose "Manage"
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
As for uninstalling the KVM device, if you want to completely remove all files from your computer, do a search (off the start menu) and search for *KVM vmDisk USB Device".
The delete all the files that are found in the search.
Let me know if I can assist you further or you need any clarification on my instructions.
Jan 12, 2011 | Avocent DSR2035 (DSR2035001) 32-port KVM...
How to unlock a sandisk cruzer usb flash card 16 gb
If you cannot open your usb drive, you will need to open your drive management. Sometimes, drive letters that the usb drive looks for, usually F, G or H, are taken by other drives. You can change drive letters on other network drives to different letters, therefore, allowing the usb drive to access the letters it is looking for, and effectively, unlocking it. Below are directions on using the Disk management utility in windows:
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility. Also, drive '0' is usually your main hard drive.
A menu will open
Chose "Manage"
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Jan 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
When I use two-sided printing the first 9 pages are printed and then the last 3 or 12 are printed separately (preview also previews 9 pages and another screen shpws 3 pages - as of they were 2 diff docs).
Perhaps you have broken out the document into two or more sections? Each section has separate settings for page margins, etc. Make sure your page breaks are only page breaks and not section breaks. Hope that helps,
-Vince
Oct 01, 2008 | Office Equipment & Supplies
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
