Eror sc548 what is eror sc548? how can we delate this scam
  • 68 Answers
Here is the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad thermistor, a bad fusing lamp or a bad connector.
Posted on Oct 03, 2009
  • Office Equip... Master
  • 1,297 Answers
If you have a Ricoh copier the problem is in the fuser unit.Enter in the service mode:press the total clear key-107-stop/clear key,open the front door and turn off the copier,unplugged and wait 10 sec.Turn ON the power switch after plugged the copier and close the front door.
Posted on Sep 29, 2009
  • 48 Answers
I have been a ricoh tech for 21 years. SC 541,544 etc are heat related error codes. They are designed to shut down the machine when the thermistor (sensor that reads temperature) detect a higher or lower temperature then that of the pre determined operating temperature. Imagine what could happen if your machine warmed up and up without stopping? This could potentially create a fire and/or have a meltdown condition within the copier. Its for safety reasons for you and your machine.
Think of a car that is over heating but your dashboard not having a temperature gauge to alert you. You would eventually blow your heads or engine.
Posted on Oct 20, 2009
Service call SC548
SC 548 - Fusing unit set error or fusing unit installation error,differ to copier models.Try reset by open/close the front door or enter in SP mode and turn ON/OFF the copier.
Mar 25, 2013 | Ricoh Office Equipment & Supplies
SC548 AND SC990
Sc548 can generally only be reset by entering service mode, and generally is caused by a defective thermistor (thermostat) in the fuser, and/ or power fluctuations. Sc990 is a software issue. I'd consider a new HDD> You'll need a tech for these problems.
Aug 13, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh copier 4022 sc542 sc548 error codes after changing with photo conductor unit type 1027,
If I'm not mistaken, that type of photoconductor is not compatible with your particular model of machine. The SC542 and SC548 errors are related to the fuser unit. It is not warming up correctly. It could be that it needs replacement thermostats or thermisters. It's possible that the incompatible drum unit has created this problem.
Mar 11, 2011 | Office Equipment & Supplies
Gestetner dsm645 error code sc548 solutions of free
SC548 is fuser belt rotation error, check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion, I think they have been modified, but I don't have the part number, sorry. Allso check the firmware is up to date.
Feb 19, 2011 | Gestetner DSm645 Digital Imaging System
Tenho problemas na minha fotocopiadora Ricoh 1027,aparece no ecram código SC548.qual saida para situação
SC548: Fusing unit set error
Symptom: The machine does not detect the fusing unit.
Possible Cause: • Poor connection of the fusing unit
• The fusing unit is not installed
Jan 09, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
What does Service code SC548 on a Lanier LD435c stand for
AMCAP VIDEO CAPTURE WILL NOT FUNCTIONPROPERLY
Aug 16, 2009 | Lanier UNKNOWN
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
238 people viewed this question
k24674
jasbo
jasbo
