Problem to feed photo paper
Problem to feed A3 photo paper ex 250gsm, paper will stop or jam right before the measurement sensor(blue lights)and I get error :no paper or unexpected paper size
I have still problem, even if I use A4 180GSM photopaper.look like paper stop at last roller guide before paper are in position for printing. I was also able to print thick photo paper before, printer is 2 years old.
Posted on Sep 29, 2009
    Problem Solver:
  • 7 Answers
Pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Mx2600n is having paper jam BTW the black and white roller before the Fuser unit
There are a number of reasons why the paper would jam at registration. First off, if the paper is completely flat & straight it is probably a feed issue or paper detect issue. There are 2 little black photo reflectors before the rollers in the centre of the feed path. These sensors can get covered with paper dust & may need cleaning. Also try feeding paper from the manual feed tray & see if it jams. If you have jams from both cassette's & manual feed then its most likely a sensor of feed issue. If its from one tray only then the sensors in the vertical path may be dusty with paper dust or worn pick up & feed tyres. There is also an issue with the feed clutches in the paper pick up drive unit which can fail & have been upgraded.
Secondly, if the paper is Z folded at the registration rollers but before the fuser then it could be the primary bed drive gear. This gear also drives the secondary belt unit located in the right hand door assembly.
Hope this helps.
Dave.
Jan 11, 2017 | Sharp Mx2600n Color Copier, Printer,...
Paper feed jams on right hand side after I pulled bits of an A4 that came out ripped
Bruno:
You did not get all the pieces of that A4 paper out of the paper path. There is still a small shard of paper in the right side of the paper feed area. Use a flashlight to look carefully in the paper feed area and gently use tweezers to remove the piece of paper. If you pulled the sheet of A4 paper backwards out of the feed area, you may have dislodged the paper feed sensor (a small plastic finger that sticks down in the paper path to tell the printer that the paper has passed.) Be careful with the tweezers... if you break that sensor, there is no fixing it.
Jun 21, 2015 | Epson Stylus Photo R2400 InkJet Printer
Peaper button error
Paper feeding sensor lever is jam, so check the paper sensor right side of feeding.
Jun 11, 2013 | Epson STYLUS R230 InkJet Photo Printer
Copier keeps giving paper jam on A4 sheet feed although no paper is jammed. A3 Feed is no problem. Is tthere sensors that need cleaning etc??
please pull the tray out and check machine properly .may be there is any small piece of paper .remove it check machine from inside and fuser unit also..if the problem stills check all sensors by manually moving and cleaning ..problem will be solved
MIAN JEE
Sep 24, 2011 | Canon iR 2022 Printer
HI MY DESKJET 9800 WILLNOT FEED A3, IT JAMS ON THE LEFTHAND SIDE EVERY TIME, I HAVE LOOKED TO SEE IF ANYTHING IS OBSTRUCTING DUE TO BEING IN STORAGE FOR A WHILE. A4 FEEDS CORRECTLY, BUT CANNOT FIGURE OUT...
If A4 is ok but A3 jams then I would have to say there IS something hitting the paper. Try another A3 sheet and when it jams, pull the paper back out (after the printer is switched off) very slowly. When its out take a look at the leading edge and you will see a kink in the edge of the paper. Now place the paper back in the input tray and look at where the kink is in relation to the machine. That will tell you exactly where the obstruction is.
I hope you understand what i am trying to say.
Jul 10, 2011 | HP DeskJet 9800 InkJet Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
Dx8400 will not take 260gsm photo paper
Maximum thickness allowed in this printer is 250gsm for Premium Glossy, therefor the paper appears to outside the specification of the machine. Only answer is use slightly lighter paper.
Nov 18, 2008 | Epson Stylus Photo R300 InkJet Printer
193 people viewed this question
jasbo
jasbo
