Question about Radio Communications
Help shep vary noisy while driving i driving a 1999 dodge Dakota
    Champion:
  • 219 Answers
Have your antennas checked..get the swr read
Posted on Nov 21, 2009
1999 dodge dakota 3.9 v-6 shuts off when driving?
check for codes if you have a p0320 code replace crank shaft sensor
Jul 23, 2014 | 1999 Dodge Dakota
1999 dodge dakota sport 3.9 v-6 just stops running while driving?
Probably some sensor is failing. Have your engine codes scanned. many auto part stores will scan your vehicle codes.
1989 dodge dakota pickup hard to start when hot and sometimes dies out while i am driving an plenty black smoke comes out the exhaust pipe
You should start by doing a compression test on the engine. They are loaner tools from autozone. Once you do that, if your compression between cylinders varies ~20psi, there is an internal problem with your engine. Could be worn seals or rings.
Sep 23, 2010 | 1989 Dodge Dakota 2WD
Need a diagram for a 99 Dodge Dakota Sport wiring from spark plugs to distributer cap
1999 Dodge Dakota 3.9 liter V-6 VIN "X"
1999 Dodge Dakota 5.2 liter V-8 VIN "Y"
Hope this help (remember comment and rated this).
Aug 04, 2010 | 1999 Dodge Dakota
Torque spec for king nut on front spindle of 1999 2 wheel drive dodge dakota?
Unsure as to what you are calling the King nut but here are the torque specs for your front end.
Steering Gear-To-Cradle Bolt...........135 ft pnds
Steering Gear-To-Crossmember Bolt (Dakota 2 WD)..........190 ft pnds
Suspension Cradle Plate To-Cradle Attaching Bolt..............123 ft pnds
Tie Rod End-To-Steering Knuckle Nut Dakota (2WD) .............65 ft pnds
Tie Rod Lock Nut.....................55 ft pnds
Dec 08, 2009 | 1999 Dodge Dakota
1999 dodge dakota manual transmission wont come out
If the tranny housing is aluminum and the locating pins are steel they will corrode creating a bond.
It will come apart providing all bolts are removed and not easily!
When replacing tranny put antiseize on all aluminum and steel contact points to prevent future corrosion.
I hope this helps.
Apr 19, 2009 | 1999 Dodge Dakota
Can I bypass the AC compressor by buying a serpentine belt for a 1999 Dakota 3.9 w/o AC? The compressor is noisy(bearing?) and the system already had a leak.
the one without ac has an ac delete pulley that sits where the ac pump would go, so the answer is no, buy the pulley.
Apr 09, 2009 | 1999 Dodge Dakota
Ac clutch going out on 93 dodge dakota
If the clutch is noisy from a bad bearing then don't drive far,if the compressor clutch pulley bearing seizes up it will freeze the pulley and the belt will burn off, and you are stuck, if you mean the anything else besides this drive it.
Dec 08, 2008 | Mercedes-Benz 400-Class Cars & Trucks
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
