Press start button nothing happens - malber p28
I have problems getting it to start. Help??
  • Washing Mach... Master
  • 2,605 Answers
If you've determined the unit has power, does it fill with water, or just nothing ?
Posted on Sep 29, 2009
My sens p28 notebook does not start, when I press the power button fan run about one or two seconds and after off. please help me.
Hello, Take out the battery and unplug power cord and let set for about 30 mins and then just plug in the power cord and hit the power button and see if works, If neither work then the laptop will have to be repaired.
Sep 29, 2015 | Computers & Internet
Malber P28 washer. On hot water cycle the drum is part filling with water then stopping wash cycle and door is unlocking. I was able to open the front loading door with the drum half full of water - gushed...
Sounds like a control pcb malfunction. Remember that you are dealing with MAINS Voltages which can be lethal.
Never continue to use a machine that floods or enables random water release for any reason. The end result might be Electrocution, and it is certainly not worth that risk
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Malber P28 Front Load All-in-One Washer /...
P28 laptop blue screen it starts up with the windows logo then shuts down
hello
i have problem my laptop no work and i search laptop P28. i want buy model laptop P28. i need in changer block mainboard for loptop P28
If you can me help. please help me. i buy old laptop Samsung P28
hope you help me
Thank you
my e-mail: Live29@yandex.ru
Sep 24, 2009 | Samsung V25 XVC 2800 Notebook
Samsung p28 not srarting up
If the battery is old, it will not charge enough to power up the unit. Take it to a computer shop and have them test it for you.
Sep 04, 2009 | Samsung V25 XVC 2800 Notebook
Water runs into drum when machine is off!
See what happens if you completely remove electrical power from the machine (by turning off at the wall, or unplugging it) If the water keeps coming in even with the power off(easily the morelikely outcome), then you need to replace the fill valve. On most machines, you get to this by taking the top cover off and looking inside at the point where the water inlet hose comes in. The plastic fitting that the hose screws onto is in fact part of the valve that you want to replace (you'll recognise it by the row of solenoid valves - 2 or 3 of them, each with a pair of wires on the top, and a hose trailing off to some part of the machine coming out the bottom). Fitting a new one is quite easy - just make sure you mark all the hoses and wires before you remove the old valve so you can put them all back in the right place. If the problem goes away when you turn the power off (a far more unlikely result), then you need to look for problems with the programmer and wiring. Tracking these down is a lot more involved, and potentially more expensive. A.
Jun 07, 2009 | Malber P28 Front Load All-in-One Washer /...
Malber doesn't even turn on.
Clight16 is very likely to be correct. I repair Malbers (in the Wash. D.C. area) and have found door switches to cause these symptoms 90% of the time. BUT, that doesn't necessarily mean replacing the switch. Here's how to test: First, check out the little square hole where the door latch (on door) fits into the machine. You'll see a white plastic "frame", and behind it, a black plastic piece that slides to the right. We'll be sliding that "slider" a little later. OK. Turn machine off (if it's been on). Wait about 2 mins until "safety latch" disengages. (Don't force handle - it can break!). Open door. Set top right knob to "Off" position. Press "Start" button (power on). Turn top right knob to "Beginning of wash cycle". Because door is open, nothing happens - yet. Finally, using a small screwdriver, or other thin object, slide that black plastic "slider" over to the right (about 1/4 inch). Don't be afraid. There is nothing anywhere back there that you can hurt - or that can hurt you. It's totally safe! That simulates the door closing and the metal latch forcing the slider over. My hunch is, the machine will start working (filling with water). If so. you have a simple (and free) fix. The problem is: the metal latch is not forcing the "slider" over to the right far enough. To fix: You need to "allow" the latch to move a little further to the right. To do this, you'll enlarge the hole (on the back of the door) the latch protrudes through. The square hole is sized to stop the spring-loaded latch in the exact right spot. Press the latch back, and file (or scrape) away a little plastic on one side of that little square hole - so when you release the latch, it snaps over a bit farther than it did before. You only need the latch to "lean" over a LITTLE farther (1/16") so only remove 1/32" of plastic. That should do it. And may God bless.
Jan 25, 2009 | Malber P21 Front Load Washer
Malber dryer 2 years old
move the dial to the "off" position first; wait for beep; then move to the drying setting you want, and wait for another beep.
Jan 06, 2008 | Malber TD700 Electric Dryer
Getting the dryer to start after turning it off.
Suggestion: Switch off wall plug and restart to dry.
Jun 26, 2007 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
