Question about GE 24 in. GSD4020Z Built-in Dishwasher
Kenmore Dishwasher leaking from bottom but not while draining....
My dishwasher leaks from the bottom of tub but only when filling not when draining only. Could this still be the sump seal or would it leak while draining too?
    President:
  • 3,433 Answers
Leak is associated with the water pump, either a hose or seal
Posted on Sep 29, 2009
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
Bosch shu8805 (2002 model)
HI,
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 18, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Frigidaire built in dishwasher leaking water out of the bottom.
One of the reasons could be door seal or sump seal leaking. But if the leak only occurs at a particular time in the cycle then most likely the wash motor or drain motor seals.
Need the model number to make a more closer assessment.
Dec 31, 2012 | Frigidaire Dishwashers
My dishwasher is leaking onto my kitchen floor.
This is most likely either due to a clog in the drain line or the seal around the sump being at fault. It depends where your unit is leaking from. If you remove the bottom kick plate from the unit you should be able to see where the water is leaking from if it is in the middle of the unit most likely you would have to replace the sump and sump gasket if it is off to the side of the sump then it might be the drain pump being clogged or blocked with something that is makeing it leak. If you have any further questions message me back and Thanks again for using Fixya
Rick
Jun 11, 2011 | Kenmore 15529 Built-in Dishwasher
My maytag neptune tl leaks from the bottom while it washes MODEL #FAV6800AWW it leak about two to three cups of water for each load,about one drop per second.
Possible Tub Seal leak, leak from Outer Tub, Sump Cap, Drain Pump, Drain Line.
You need to pull the front cover off the machine and ID the leak source. If there wash water over the Clutch Pulley I would suspect a Tub Seal issue.
You can't link to the Service Manual form this site.
Google Maytag Neptune load unbalance and see if you can find support for the Service Manual.
Oct 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Dishwasher leaks, not the valve, comming from underneith right side. looks like its comming from the sump. Pump seal??
There is a seal that goes around the sump that possibly has failed. The part number is 5304460995, however, you should check the screws that hold teh sump to the tub, as they may have come loose. If it's the pump seal leaking, the pump would need to be replaced, as they aren't serviceable
Mar 28, 2010 | Frigidaire FMB330RGB Built-in Dishwasher
Maytag mdb7100awb dishwasher is leaking from the bottom right corner. starts to leak almost immediately upon starting it. I then opened it and found that the entire tub is filled with water, looks like it...
take off the bottom panel there are 4 screws you got take they are 1/4 inch screws  once the panel is off turn on the dishwasher and see where exactly the leak is coming from
Jun 07, 2009 | Maytag MDB7100AWB Dishwasher
Leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Feb 05, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Water seeping in dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Whirlpool dishwasher leaks everywhere
your tub seal needs to be replaced. you might have damaged it when you moved it
Jan 25, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
GE 24 in. GSD4020Z Built-in Dishwasher Logo
250 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
