Asrock P4I45GV R5 Motherboard Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No beep no display only monitor and only cpu heatsing fan runing
Same as above
  • Anonymous May 11, 2010
    can you explain your problem properly please so i can help you for any thing
  • Aseem May 11, 2010
    you question is not clear what exactly is the problem you are facing
Anonymous
Level 3:
  • Master 700 Answers
  • Posted on Sep 30, 2009
Anonymous
Master
Level 3:
Answers
700
Questions
Helped
268765
Points
2031
If you are saying that monitor is working only that it has " no signal" or display? But also processor heat sink fan is running?
Well if that's the case, the probable cause would be memory card dirty contact or faulty. Try reseating it or clean it using a gel eraser. How?
Power off the unit, detached the AC cord from wall socket and UPS if you have for complete power isolation, take the side cover, touch the bare metal of the case before proceeding to take out the memory card. Reseat or clean, Assemble in reverse. Then power it up again. If still not have a good working RAM card on hand or take the ram on the next memory slot with same socket spec.
It should work now. If not you gonna use the "minimal component troubleshooting"
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
1helpful
Computer shuts down when xp loads
Follow CPU FAN and the temperature of the CPU from BIOS under the PC health.Or you can change the RAM if you have a spare .Some times CPU FAN or HEATSING base broke ,so you should check the base of the CPU FAN>You can open the cpu and apply correct heatsing paste.
Follow some links
http://www.pcbuyerbeware.co.uk/BIOS.htm
Regard's
Shibuda
3helpful
3answers
Motherboard display problem
Hear some any beeps to your motherboard. If your hear this beeps then motherboard will identify what is the loss connection of trouble of your MOBO.
If you don't then have to remove tor clear the CMOS by removing the Lithium Battery in it.
Monitor is not on
Im gonna take it that "yup i'm hear the any beep" means you do hear a beep.
So first If it has an onboard vga card. remove the second vga and hook the monitor up to the onboard and try to boot.
Second try the Power Supply, make sure whatever power supply you use has enough to handle all the equipment in the unit.
If those two don't solve the problem, then you have a bad motherboard.
1helpful
Led pwr+hd isn on, cpu fan is runing, but no
if your monitor is working properlly,then you should check the following things:-Remove ram and start the computer. If it gives you any beep then your motherboard is all right.And if not,then it's time to buy a new motherboard.
2helpful
2answers
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
2helpful
2answers
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Monitor
Reset the Cmos battery,check the RAM,check the smps or check the motherboard ground, I think you problem will solve.
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
