Question about Sharp Office Equipment & Supplies
We have a sharp AL 1610 that shows CH f 5 on the display and has the light that looks like a belt drive showing. What does that mean?
    Scholar:
  • 118 Answers
It appears you have two faults showing up. A 'CH' fault means there is a door or hatch that's open or ajar. Check to make sure the unit is buttoned up correctly.
An F5 code means your copy lamp isn't turning on and off correctly. I recommend that you have a trained service tech diagnose the problems with this machine.
Posted on Oct 01, 2009
IT SHOWS CH ON DISPLAY PANEL
In all type of sharp copier there is tow type of ch code , if you have blinking ch that mean you have Check the developer unit re insert it probable i, if you have stead CH that mean you have to check the door properly there is an open door .
than you for using fixya
Jan 31, 2011 | Sharp Office Equipment & Supplies
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHOW CH CODE
Hello sir ; CH code it means some where the door is open ,check the side door.
Sep 30, 2009 | Sharp AL 1631 Copier
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
What does "CH" mean?
On the Sharp copiers when the "ch" is blinking means that the toner cartridge is not in or it may be the wrong cartridge. Some sharp cartridges look alike and will fit into the machine but are the wrong one.
Hope that helps...
Lbcoaster
Feb 18, 2009 | Sharp AL-1642CS Copier
Green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Dec 24, 2008 | Sharp AL 1631 Copier
Sharp copier al1631 , putin new toner sometimes shows CH
the drum might not be rotating due to either the drum gear is wornout or the drum drive gear on the machine main drive unitis wornout.
Nov 26, 2008 | Sharp AL 1631 Copier
Sf 7800 sharp copier
-Did you try to replace the Toner Cartridge? if not try to replace and installed properly.
or check the Toner Cartridge if installed properly.
Sep 20, 2008 | Sharp AL 1215 Black and White Copier
Sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
May 26, 2008 | Office Equipment & Supplies
CH Error
CH means your toner cartridge is needing replaced.
Feb 25, 2008 | Sharp AL-1551CS Printer
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
