Question about Maytag Neptune MDE5500AY Electric Dryer
How do I locate coils
The dryer is a whirlpool model LGR8648PWO. The coils burned out about tywo years ago, and now the same thing is happening again. I do not want to pay someone for a five minute repair. WHERE ARE THE COILS LOCATED? How do I remove them once I find them?
    President:
  • 1,304 Answers
You need to remove the four door screws,
take off the door , remove the white cowel
remove the top dogs
open the top and look behind the tumbler
Posted on Oct 03, 2009
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
I have a whirlpool LGR8648pwo. Runs not heat and timer doesnt move. I found a 4 prong sensor in the back of the unit. 2 prongs have continuity and the other 2 dont. Is that bad.
If no heat at all i suspect this part HERE. This is the fuse. It kills power to the gas assembly if junk gets into the filter housing and cause an overheat condition. On electric models this same fuse kills the whole dryer. On gas models it just kills the gas. If that is good the next thing to check is the flame detection sensor mounted out side of the burner chamber. It's job is to power up the ignitor. If it is open no power can get to the ignitor. If it is good then the next thing to check is the ignitor. If the ignitor is good AND you are getting power from that control klixon you mentioned with the 4 wires on it AND you can get a little heat at first but then none at all them coils need to be replaced. Here is my home video:
Dec 09, 2012 | Whirlpool LGR8648 Gas Dryer
Whirlpool Dryer model LER4624BW2 doesn't get hot enough
What was your solution? I was thinking one or more of the multiple coils in the element could be burned out but not the entire thing I've see that happen before. Glad you got it fixed!
Mar 31, 2012 | Whirlpool Dryers
Whirlpool lgr8648pwo is not drying clothes in the dryer, not hot enough.
the link below has several videos that explain how to repair your dryer.
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Dryers
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
Dryer starts when it wants too
you maby have a weak thermal fuse.
Mar 15, 2009 | Whirlpool GEX9868J Electric Dryer
My dryer doesnt heat.
hi there,
check the ignitor and the coils on the burner assy.
Sep 30, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
