Question about RCA RS2663 Shelf System
My RCA RS 2663 CD Player won't open when I push the open button no matter how many times I disconnect it from the power. What can I do to make it open?
    Problem Solver:
  • 5 Answers
To be honest you're better off tossing this system, when I bought it back in '08 it worked perfectly fine and then 2 years later it started to have all these laser related issues e.g. it would refuse to read an mp3 disc even though it was said to be compatible with that format and it would skip on almost every disc, even newly burned CDs. I talked to customer service about the issue and they quoted me a price of 50 dollars to replace the laser but honestly, it doesn't make sense spending money on it since the system costed me 85 dollars including tax at walmart.
Posted on Jul 15, 2014
    Problem Solver:
  • 11 Answers
You have to see how are the engem comections and if it receves power but do not open put a new one
Posted on Oct 01, 2009
Two cd in same slot won't eject
Try disconnecting the CD player from power,press and hold the open button and the connect and turn player on.Release button after it indicates open on the on player.Tap the top part of the player with your palm while pressing open button.
Hope this helps.Thanks!
Oct 16, 2011 | Audio Players & Recorders
I have a rca rs 2663 stereo, The cd tray will not open or play cd's anymore. Could you please help
It two things can cause this:-
The motor is damaged ( you can listed closely to hear if the door motor runs when you try to open the tray.
Or The belt that takes power from motor to open mechanism is damaged.
Aug 19, 2011 | RCA RS2663 Shelf System
My rca rs 2764 system the cd player wont open
Hi, what makes a CD player not ejecting or not opening is because the Sim tray which carries the CD inside the player when inserted is damaged and it's not performing it suppose to. o weak to function, You will need to replace the Sim tray that allows the CD go in and out...
Have a nice day...
Feb 18, 2011 | RCA Audio Players & Recorders
I have a RCA cd player model RS 2663. It has access to radio and cassette player. The cd's stick and it does it with all of them if I change the discs. Can this be repaired or should I just purchase...
unfortunately rca sold there audio division a few years back and product support for audio is very limited,i am a tech for a rca svc center among many other brands as well ,and more often than not we run into a roadblock looking for audio parts..
Sep 09, 2010 | RCA Audio Players & Recorders
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
No power
There should be a fuse inside. Look in the back near where the cable comes in. I think it takes a micro fuse. Kind of looks like a resistor but the number next to it will say F and then a number.
Jan 28, 2009 | RCA RS2663 Shelf System
Rca rs 2620 power but no audio
I need to see if the manual has any method of button pushing to get the sound back on. Otherwise, I am not an electronic type of guy that has soldering tools, can tell a resistor from a plug, etc. if that is what is needed to get the thing going with sound.
Dec 14, 2008 | Audio Players & Recorders
RCA RS2663 Shelf System Logo
426 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
