Question about Whirlpool Calypso GVW9959K Top Load Washer
The washer wont fill with water and we have checked all the hoses
    President:
  • 1,776 Answers
Check the water inlet valve. Unplug the machine, turn off the water and remove the water supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. A lack of continuity means a bad solenoid and the valve assy will need replaced. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 29, 2009
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore 800
the height of the drain hose the higher the hose gets above the washer the higher the water will fill up to
Aug 02, 2013 | Dryers
Wont fill up with water
Do you get any water coming into the washer?
If water is not entering the washer, check that the incoming water valves are open and water flows through them. (Take off the hoses and put a bucket under the pipes.) Make sure that any filters are not clogged (for example with bits of damaged washer). Make sure that the hoses are not kinked. Next take off the hoses from the washer's fill valve and check if the filters are clogged (not present on all washers). Try replacing the hoses (there are anti-flood hoses that will seal themselves if they sense a leak). If that doesn't help, then the valves probably need to be replaced.
If water is entering the washer, check the filters at the inlet valves for partial blockages. Next check your water flow rate. (If the flow is too low, the washer may shut down. Check your manual for details or add a comment with the model number of your washer.) Next check if the water is being siphoned into the drain. This will occur if the drain hose is not positioned properly in the stand pipe (or sink). If the end of your drain hose is lower than the washer water level, this can happen.
I hope this helps.
Aug 11, 2011 | Whirlpool Washing Machines
It wont cycle thru anything
There could be several reasons for washer not to fill .Fill washer with water and wait for the timer to get to the drain mode.Unplug the washer from the electric outlet.Open the case, and disconnect the water hose from the outlet of the water pump.If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.Reassemble hose from step 3.Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Thanks for contacting Fixya.com
Nov 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer wont initially fill. all other operations
Check the screen on the inlet hose from water fill. If not, it is the timer that you set (it's not functional)
Jul 08, 2009 | Kenmore Washing Machines
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
Water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Apr 17, 2009 | Washing Machines
Kenmore he2 wont fill with water
first off check your incoming water supply.. also make sure your not using stainless steel hoses manufactured withthe name "flood safe"" big issue with these hoses shutting off premature(they have a built in shut off check valvewithin the hose itself, .. replacethehoses if you have these. if not and you have good incoming water supply, soundslike yo may have a faulty inlet water valve.although usually onyl no hot or no cald the fact you haveno either water temp, thats odd
Mar 04, 2009 | Kenmore HE2 Plus Front Load Washer
Washer does nothing
ok we need to check a couple of things...take the fill hose off ,,,now put unit in a cycle and make it call for water...is the inlet vavle humming or vibrating....will your there look in vavle and see if your inlet vavle screens are clogged...does the unit have water in it,,if so it wont fill with water in it...keep me posted onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine wont fill
hmmm...wool requires cold water...I'm guessing that first the hot water and now the cold water solenoid valves have become clogged with sediment. test by turning off water. then loosen the hose connection to each inlet in back of washer. then slowly open water valves and let water pour into wash tub if hose will reach, otherwise pour into a bucket. if water comes out of hose, then look for metal screens at hose connections to washer and clean those. if still no water through solenoids (after re-connecting water hoses) then may need to disassemble solenoids and clean those too.
Oct 19, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal De
