Question about Amana SXD524VW Side by Side Refrigerator
I need the wiring diagram for a side by side Amana refrigerator. Model # ASD2522WRWO1.... I need to wire the evap. fan and the evap heater
catriver
  • 878 Answers
SOURCE: Amana Refrigerator SCD22JL
Good trouble shooting TD, the evap fan runs through the defrost T-stat. Change it out and you should be set. Catriver.
Posted on Aug 15, 2007
wheelshot
  • 102 Answers
SOURCE: freezer works but refrigerator is staying at 50 degrees
Is this a French door unit? Do you see excessive build up of frost in the freezer on the back panel? Is that evaporator fan motor running? That is what circulates the air from the freezer to the refrigerator.
Posted on Apr 11, 2009
erpaalai
  • 999 Answers
SOURCE: I am looking for a wiring diagram for the Amana
Look behind the toe plate for the tech sheet. Hopefully it was not removed with the packing materials. If it is missing try here
http://www.apwagner.com/index.php?main_page=product_info&products_id=566096 the part number is RT1300013
Posted on Oct 12, 2009
  • 306 Answers
SOURCE: Evap fan won't run but is good and will run when
There is a thermostat inside the freezer that is wired in series to the fan more then likely it is bad. Looks like a round disk located on the side of the evaporator coils. If it is puffed up looking it is bad. About the size of a 50 cents piece.
Posted on Dec 07, 2009
SOURCE: finding wiring diagram whirlpool refrigerators
take off bottom cover should be on back if not look around compressor they usually leave them stuck around there
Posted on Apr 12, 2010
Low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Oct 11, 2007 | GE PSI23MGN Side by Side Refrigerator
Freezer is cold but it is not freezing foods.
When it comes to refrigerators I always have a most likely to least likely formula to try to solve the reason of why the freezer or fresh food compartment is or is not cooling properly. So knowing that the cold air comes most times from the freezer compartment I would look to see if the fan inside that compartment may just be slowing down because it is possible there is frost building behind the freezer wall due to most likely defrost not taking place and creating a huge block of snow and ice blocking air circulation.. Ice will show on the outside wall of freezer also if possibly the defrost heater is burned out. There are so great testing tutoral'son the following links! So now having your model number that most people don't think about I will look to see just what type of defrost system your model has=> ABB1927DE EVAPORATOR AREA and Rollers location 16 in photo. That part is your models=> 67002135 Defrost Heater
Amana, ABB1927DE User Manual
Sometimes the 67003636 Evaporator Fan Motor goes bad but thawing is more severe when the evap. fan goes bad and may be tricky stopping and starting on its own before true-ly burning out=> 67003636 Evaporator Fan Motor
here is a Amana ABB1927DE Wiring Diagram=> HERE
67003426 Defrost Thermostat Hey I know there is a lot of material here so I will be here if you should have questions, Thanks, Sea Breeze
Jun 01, 2011 | Amana ABB1927DE Bottom Freezer...
AMANA SIDE BY SIDE, INOP, FREEZER COILS ICE, FAN INOP IN FREEZER. REPLACED THERMOSTAT, DEFROST TIMER AND FAN, STILL INOP. HEATER WORKS AND HAS 32 OHMS.
Check the BLUE wire from the temp control to the ORANGE wire of the defrost timer for continuity. That is the complete fan circuit. You should read the resistance of the Evap fan motor. If you do not read resistance suspect the pins of the evap fan motor connector or... the Unbilical harness from near the evap to the icemaker and the evap fan. The connector pins of the Evap fan motor connector (Freezer connector) are notorious for failing.
Thanks for choosing FixYa.
Kelly
Sep 02, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Need to see if evap fans r working
http://www.beverage-air.com/uploadedFiles/docs/CFG_CRG_KF_Series809-046A.pdf
this site has your manual and the manual has wiring diagram.
also has some common trouble shooting questions and answers.
Jul 06, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
Do not know cubic size. It is a side by side approx 10 years. Motor is running but coil is freezing up in freezer, refrig side is not cooling. Evaporator fan not running so changed evaprorator motor. Fan...
The problem is still from the fan, try to settle down and try to connect the wire properly. if the wire is fix properly fan will work and refrigerator will also work.
Goodluck
Jun 28, 2010 | Amana SXD524VW Side by Side Refrigerator
Evap fan not running changed and still not running
Good day,
On some Amana models the evap fan motor runs thru the defrost thermostat. The purpose was to delay the fan restarting after a defrost cycle so it wouldn't blow warm air. If you can jump the defrost thermostat and the an runs, then changing the thermostat will solve your problem.
Other causes on Amana could be on older models the fan was run thru the fan/light switch. If it's a rocker type switch, it could be the problem.
Call the supply house where you bought the motor. Ask if the light switches are 2 or 4 terminal. Both the freezer and fresh food switches. If they are 4 terminal, then they could be the problem, or they are not depressing far enough when the door closes.
Lastly, I have come across a few Amana's where they actually had a broken wire to the motor. In all my cases it was the white wire. The area where they broke, was not at the motor but further back in the harness. You would need a VOM meter to trace the wiring.
Jun 01, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Evap fan won't run but is good and will run when hot wired. Compressor runs but cold air does not circulate through frig side nor freezer. Could defrost heater or timer keep fan from running?
Dec 07, 2009 | Amana Refrigerators
Aug 14, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling
Replace heater and defrost timer
Aug 09, 2007 | GE Profile PSW26P Stainless Steel Side by...
Amana SXD524VW Side by Side Refrigerator Logo
159 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
