Question about Brother ML-100 Typewriter
Corrector isn't working
I have replaced and checked the corrector ribbon, but I can't get it to work
  • Brother Master
  • 3,594 Answers
You may be puting it on wrong the dull side of the tape should face the paper.
DickyO
Posted on Sep 29, 2009
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
Why won't the new ink cartridge/corrector ribbon I bought, work?
there is a rubber bumper on the print solenoid the goes soft it needs replaced see a repair shop
Not correcting & corrector ribbon not moving to correct
At this point almost all selectrics suffer from a case of the gummies.
it most likely needs a tech that under stands the selectric.
DickyO
Aug 28, 2012 | IBM Correcting Selectric Iii Typewriter...
How to install corrector tape into AX325. Seems to be in place and black ribbon seems to be in place but corrector tape does not work
Be sure the correction tape is thru both guides and that the dull side faces the paper. Go to brother.com click on support you will find a manual there.
DickyO
Mar 27, 2012 | Office Equipment & Supplies
This machine gets used just a few times a year for straight typing. I was asked to replace the ribbon as the letters weren't appearing on the paper when the keys were pressed. No one knew when the last...
I'll assume this is an ibm ww. Just below the ribbon deck on the right is the ribbon feed motor try na little WD40 on the upper and lower bearings they do gum up also be sure the ribbon motor is plugged in.
DickyO
Oct 06, 2009 | IBM Office Equipment & Supplies
Keyboard will not work
A few things to check, be sure the upper cover is fully closed, be sure the printwheel is properly installed and latched in place. check that the ribbon is properly inatalled, put the old ribbon back on and see if it works.
DickyO
Apr 16, 2009 | Office Equipment & Supplies
Smith Corona PWP90 corrector cartridge problem
sounds like the corr tape doesn't have the proper tension on it. turn wheel on corr tape cartridge, or if there isn't a wheel, some don't, there is a little lever to the left and under the left side where the cart. fits down. push this until the arm on the right side moves to the left
Jan 02, 2009 | Smith Corona Wordsmith 200 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Oct 28, 2007 | Smith Corona Wordsmith 100 Typewriter
Brother ML-100 Typewriter Logo
57 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
